Configurazione Patton 4112
dnut
17 Marzo 2017
sto cercando di configurare 3CX con un Gateway Patton 4112.
Ho seguito le istruzioni qui riportate: https://www.3cx.com/voip-gateways/patton-smartnode-sn4112/
Il sistema funziona correttamente in ricezione ma non riesco ad effettuare chiamate.
Ho configurato il nr. Trunk Principale sia come 0000, 5060, 0014690000 ma continua a non funzionare.
Suggerimenti?
Qui un log dettagliato di un tentativo di chiamata verso l'esterno:
17/03/2017 17:18:37 - Event has been sent successfully
17/03/2017 17:18:37 - Sent 843 bytes
17/03/2017 17:18:37 - Sending 843 bytes to CHR
17/03/2017 17:18:37 - Sending event to Call History Receiver
17/03/2017 17:18:37 - ~Call(C:70)
17/03/2017 17:18:37 - SLA: #0 'idle' -> 'idle'
17/03/2017 17:18:37 - ~CallLeg(C:70.1)
17/03/2017 17:18:37 - InviteADS::destroy:122
17/03/2017 17:18:37 - Call(C:70) has been terminated already
17/03/2017 17:18:37 - Call(C:70): Legs count: 0
17/03/2017 17:18:37 - Stop call record for leg L:70.1[Extn:0050]
17/03/2017 17:18:37 - Removing leg L:70.1[Extn:0050]
17/03/2017 17:18:37 - L:70.1[Extn:0050]: Terminating targets, reason:
17/03/2017 17:18:37 - Leg L:70.1[Extn:0050] is terminated: Cause: BYE from PBX
17/03/2017 17:18:37 - Ignored: SE:70.1{OnHook}
17/03/2017 17:18:37 - Issue: [Pres:0050; act=Open;0;33006]
17/03/2017 17:18:37 - StatusNotification: SE:70.1{OnHook}; Skip=0
17/03/2017 17:18:37 - Device (2086139098) is used in 0 calls: []
17/03/2017 17:18:37 - Terminated from "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9 to <sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea>;tag=be4fec45; reason: Rejected
17/03/2017 17:18:37 - L:70.1[Extn:0050] Sending: OnSendResp Send 404/INVITE from 0.0.0.0:0 tid=Pjd9a49c1ce6a747e093e879b86c250a44 Call-ID=876ef162680541848f9b4b575813e891:
SIP/2.0 404 Not Found
Via: SIP/2.0/TCP 192.168.0.103:64508;rport=64508;branch=z9hG4bKPjd9a49c1ce6a747e093e879b86c250a44;alias
To: <sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea>;tag=be4fec45
From: "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9
Call-ID: 876ef162680541848f9b4b575813e891
CSeq: 2484 INVITE
Warning: 499 3cx "Not found"
Content-Length: 0
17/03/2017 17:18:37 - SendMsg from <sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea>;tag=be4fec45 to "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9
17/03/2017 17:18:37 - Call(C:70) is terminated
17/03/2017 17:18:37 - Reported(Delete): SE:70.1{OnHook}
17/03/2017 17:18:37 - Issue: [Pres:0050; act=Open;0;33005]
17/03/2017 17:18:37 - [CM503020]: Call(C:70): Normal call termination. Call originator: Extn:0050. Reason: Not found
17/03/2017 17:18:37 - [CM503016]: Call(C:70): Attempt to reach <sip:[email protected]:5060> from Extn:0050 has failed. Reason: Not Found
17/03/2017 17:18:37 - [CM503014]: Call(C:70): No known route from Extn:0050 to target: <sip:[email protected]:5060>
17/03/2017 17:18:37 - Call(C:70): from Extn:0050 to 3335492908 doesn't match any outbound rule. No outbound rule could be selected.
17/03/2017 17:18:37 - [Flow] Target endpoint for 3335492908 can not be built!
17/03/2017 17:18:37 - Rule patton_gateway: mask=; exts=; prior=0; numlen=; type=0; from: 0050
17/03/2017 17:18:37 - Looking for outbound rule: dialed = [3335492908], processed: [3335492908]; from-ext:
17/03/2017 17:18:37 - [Flow] Building target endpoint to 3335492908 from "Test Test" <sip:[email protected]:5060>
17/03/2017 17:18:37 - [CM503010]: Call(C:70): Making route(s) from Extn:0050 to <sip:[email protected]:5060>
17/03/2017 17:18:37 - SelectRouteReq
17/03/2017 17:18:37 - Remote SDP is set for leg L:70.1[Extn:0050]
17/03/2017 17:18:37 - OnOffer from "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9
17/03/2017 17:18:37 - [CM505001]: Endpoint Extn:0050: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 15.0.60903.0] PBX contact: [sip:[email protected]:5060]
17/03/2017 17:18:37 - Reported(Insert): SE:70.1{Calling}
17/03/2017 17:18:37 - Issue: [Pres:0050; act=Alerting;0;33004]
17/03/2017 17:18:37 - StatusNotification: SE:70.1{Calling}; Skip=0
17/03/2017 17:18:37 - Inbound DID: ''; Phonebook Name: ''
17/03/2017 17:18:37 - [CM500002]: Call(C:70): Info on incoming INVITE from Extn:0050:
Invite-IN Recv Req INVITE from 192.168.0.103:64508 tid=Pjd9a49c1ce6a747e093e879b86c250a44 Call-ID=876ef162680541848f9b4b575813e891:
INVITE sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea SIP/2.0
Max-Forwards: 70
Contact: "Test Test" <sip:[email protected]:63766;rinstance=0-305f23245d6044ddb3f3ba5308f5c804;ob>
CSeq: 2484 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Type: application/sdp
Proxy-Authorization: Digest username="0001",realm="3CXPhoneSystem",nonce="414d535958cc0c5d38:2002cecfc44e627968e59f86366e8e29",uri="sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea",response="24c209a4e598a2292176c58b843b3bda",algorithm=MD5
Supported: replaces, 100rel, timer, norefersub
User-Agent: 3CXPhone for Windows 15.0.60903.0
Content-Length: 424
v=0
o=- 3698759912 3698759912 IN IP4 192.168.0.103
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 42014 RTP/AVP 3 18 0 8 9 96
c=IN IP4 192.168.0.103
b=TIAS:64000
b=AS:84
a=rtcp:42015
a=sendrecv
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
m=video 0 RTP/AVP 31
c=IN IP4 127.0.0.1
17/03/2017 17:18:37 - [CM503001]: Call(C:70): Incoming call from Extn:0050 to <sip:[email protected]:5060>
17/03/2017 17:18:37 - Leg L:70.1[Extn:0050] has external party ID {}
17/03/2017 17:18:37 - Outbound URI is used: sip:[email protected]:63766;rinstance=0-305f23245d6044ddb3f3ba5308f5c804;ob
17/03/2017 17:18:37 - Device (2086139098) is used in 1 calls: [70]
17/03/2017 17:18:37 - Source endpoint: Ext.0050; dev=Dev(2086139098):[sip:[email protected]:63766;rinstance=0-305f23245d6044ddb3f3ba5308f5c804;ob / 0050]; disp.name=Test Test
17/03/2017 17:18:37 - IncomingCall: C:70 from <sip:[email protected]:5060> to <sip:[email protected]:5060>
17/03/2017 17:18:37 - Legs count: 1
17/03/2017 17:18:37 - Added leg L:C:70.1[No endpoint yet]
17/03/2017 17:18:37 - UasSession 67403 started
17/03/2017 17:18:37 - Call from "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9 to <sip:[email protected];tag3cx=1a0df01684e845f7a35e22152a6235ea>;tag=be4fec45
17/03/2017 17:18:37 - Caller "Test Test"<sip:[email protected]>;tag=d3ef5d62ef2e4251b95531449b7c8fc9 has been authenticated successfully from IP 192.168.0.103
17/03/2017 17:18:29 - Event has been sent successfully
17/03/2017 17:18:29 - Sent 1832 bytes
17/03/2017 17:18:29 - Sending 1832 bytes to CHR
17/03/2017 17:18:29 - Sending event to Call History Receiver
17/03/2017 17:18:29 - ~Call(C:69)
17/03/2017 17:18:29 - SLA: 9999#0 'idle' -> 'idle'
17/03/2017 17:18:29 - ~CallLeg(C:69.2)
17/03/2017 17:18:29 - InviteADS::destroy:121
17/03/2017 17:18:29 - SLA: #0 'idle' -> 'idle'
17/03/2017 17:18:29 - ~CallLeg(C:69.1)
17/03/2017 17:18:29 - InviteADS::destroy:120
17/03/2017 17:18:29 - Call(C:69) has been terminated already
17/03/2017 17:18:29 - Call(C:69): Legs count: 0
17/03/2017 17:18:29 - Ignored: SE:69.2{OnHook}
17/03/2017 17:18:29 - Issue: [Pres:9999; act=Open;0;33003]
17/03/2017 17:18:29 - StatusNotification: SE:69.2{OnHook}; Skip=0
17/03/2017 17:18:29 - Stop call record for leg L:69.2[VMail:9999]
17/03/2017 17:18:29 - Removing leg L:69.2[VMail:9999]
17/03/2017 17:18:29 - L:69.2[VMail:9999]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
17/03/2017 17:18:29 - Leg L:69.2[VMail:9999] is terminated: Cause: BYE from local
17/03/2017 17:18:29 - Issue: [Pres:9999; act=Open;0;33002]
17/03/2017 17:18:29 - Device (263228998) is used in 0 calls: []
17/03/2017 17:18:29 - L:69.2[VMail:9999] got Terminated Send Req BYE from 0.0.0.0:0 tid=0972b057ce4f0e04 Call-ID=FdEzJqO3CBKbrEQfXDueog..:
BYE sip:[email protected]:5483;rinstance=ac037097575af384 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---0972b057ce4f0e04;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5060>;tag=e422796c
From: "Test Test"<sip:[email protected]:5060>;tag=c280722d
Call-ID: FdEzJqO3CBKbrEQfXDueog..
CSeq: 2 BYE
User-Agent: 3CXPhoneSystem 15.0.62928.5 (62928)
Content-Length: 0
17/03/2017 17:18:29 - Terminated from <sip:[email protected]:5060>;tag=e422796c to "Test Test"<sip:[email protected]:5060>;tag=c280722d; reason: LocalBye
17/03/2017 17:18:29 - L:69.2[VMail:9999] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=d50fa81076e81946 Call-ID=FdEzJqO3CBKbrEQfXDueog..:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---d50fa81076e81946;rport
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
17/03/2017 17:18:29 - SendMsg from "Test Test"<sip:[email protected]:5060>;tag=c280722d to <sip:[email protected]:5060>;tag=e422796c
17/03/2017 17:18:29 - [CM503008]: Call(C:69): Call is terminated
17/03/2017 17:18:29 - L:69.2[VMail:9999]: Terminating targets, reason: SIP ;cause=200 ;text="Call terminated on user request"
17/03/2017 17:18:29 - Reported(Delete): SE:69.2{OnHook}
17/03/2017 17:18:29 - Issue: [Pres:9999; act=Open;0;33001]
17/03/2017 17:18:29 - Blocking refers for the Call(C:69)
17/03/2017 17:18:29 - Call(C:69) is terminated
17/03/2017 17:18:29 - Call(C:69): Legs count: 1
17/03/2017 17:18:29 - Stop call record for leg L:69.1[Extn:0050]
17/03/2017 17:18:29 - Removing leg L:69.1[Extn:0050]
17/03/2017 17:18:29 - L:69.1[Extn:0050]: Terminating targets, reason: SIP ;cause=200 ;text="User hangup"
17/03/2017 17:18:29 - Leg L:69.1[Extn:0050] is terminated: Cause: BYE from 192.168.0.103:63766
17/03/2017 17:18:29 - Reported(Delete): SE:69.1{OnHook}
17/03/2017 17:18:29 - Issue: [Pres:0050; act=Open;0;33000]
Ciao da quanto ho potuto capire dal log che hai allegato mancano le regole in uscita.
Se non le configuri correttamente non potrai mai effettuare le chiamate.
Di per sè non sono difficili da configurare però ti ci vuole un po' di dimestichezza con il programma.
Se leggi attentamente la guida nell'ultima parte ti spiega dove andare a configurare.
Buon lavoro.
Ciao giuffro.
grazie per la risposta.
Ecco la versione del log con una regola di uscita configurata:
17/03/2017 18:23:53 - There's 28 contact(s) registered
17/03/2017 18:23:53 - Endpoint ParkOrb:SP7 has refreshed contact <sip:[email protected]:5483>
17/03/2017 18:23:53 - Update registration: key=SP7;contact=sip:[email protected]:5483;rinstance=c70b59eef68754ea; id=21
17/03/2017 18:23:53 - Dev(265148850):[sip:[email protected]:5483;rinstance=c70b59eef68754ea / SP7]: PBX contact is local IP: <sip:[email protected]:5060>
17/03/2017 18:23:53 - Selected source IPv4 127.0.0.1 for destination 127.0.0.1
17/03/2017 18:23:53 - Updating device Dev(265148850):[sip:[email protected]:5483;rinstance=c70b59eef68754ea / SP7] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=6dfe911a01db5a17 Call-ID=mDMMVjHBtG-qec9w3EWuHQ..:
REGISTER sip:127.0.0.1:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---6dfe911a01db5a17;rport=5483
Max-Forwards: 70
Contact: <sip:[email protected]:5483;rinstance=c70b59eef68754ea>
To: "SPSP7:"<sip:[email protected]:5060>
From: "SPSP7:"<sip:[email protected]:5060>;tag=ec70d34b
Call-ID: mDMMVjHBtG-qec9w3EWuHQ..
CSeq: 2006 REGISTER
Expires: 300
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="SP7",realm="3CXPhoneSystem",nonce="414d535958cc1ba889:2fdfdef79864ebe025d1042c2ceeeada",uri="sip:127.0.0.1:5060",response="53f3c524546d07f0543fcebdde7c230b",algorithm=MD5
Supported: replaces
User-Agent: 3CX Parking Orbit
Content-Length: 0
17/03/2017 18:23:53 - Found 1 contact(s) for AOR sip:[email protected]
17/03/2017 18:23:53 - Update AOR sip:[email protected] with contact [<sip:[email protected]:5483;rinstance=c70b59eef68754ea>]
17/03/2017 18:23:53 - Caller "SPSP7:"<sip:[email protected]:5060>;tag=ec70d34b has been authenticated successfully from IP 127.0.0.1
17/03/2017 18:23:52 - Event has been sent successfully
17/03/2017 18:23:52 - Sent 1909 bytes
17/03/2017 18:23:52 - Sending 1909 bytes to CHR
17/03/2017 18:23:52 - Sending event to Call History Receiver
17/03/2017 18:23:52 - ~Call(C:91)
17/03/2017 18:23:52 - SLA: #0 'idle' -> 'idle'
17/03/2017 18:23:52 - ~CallLeg(C:91.1)
17/03/2017 18:23:52 - InviteADS::destroy:156
17/03/2017 18:23:52 - Call(C:91) has been terminated already
17/03/2017 18:23:52 - Call(C:91): Legs count: 0
17/03/2017 18:23:52 - Stop call record for leg L:91.1[Extn:0050]
17/03/2017 18:23:52 - Removing leg L:91.1[Extn:0050]
17/03/2017 18:23:52 - L:91.1[Extn:0050]: Terminating targets, reason:
17/03/2017 18:23:52 - Leg L:91.1[Extn:0050] is terminated: Cause: BYE from PBX
17/03/2017 18:23:52 - Ignored: SE:91.1{OnHook}
17/03/2017 18:23:52 - Issue: [Pres:0050; act=Open;0;33607]
17/03/2017 18:23:52 - StatusNotification: SE:91.1{OnHook}; Skip=0
17/03/2017 18:23:52 - Device (2086139098) is used in 0 calls: []
17/03/2017 18:23:52 - Terminated from "Test Test"<sip:[email protected]>;tag=a4b199e334674aaeb3573a05a0442a3b to <sip:[email protected];tag3cx=219346e30389427992b857c8e6316ecc>;tag=0b0d3e16; reason: Rejected
17/03/2017 18:23:52 - L:91.1[Extn:0050] Sending: OnSendResp Send 500/INVITE from 0.0.0.0:0 tid=Pj0ad57087772f4667b320d0ae963a6d8f Call-ID=d50538fff1c74fd8a1598304f1a03fa0:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/TCP 192.168.0.103:50232;rport=50232;branch=z9hG4bKPj0ad57087772f4667b320d0ae963a6d8f;alias
To: <sip:[email protected];tag3cx=219346e30389427992b857c8e6316ecc>;tag=0b0d3e16
From: "Test Test"<sip:[email protected]>;tag=a4b199e334674aaeb3573a05a0442a3b
Call-ID: d50538fff1c74fd8a1598304f1a03fa0
CSeq: 23693 INVITE
Warning: 499 3cx "Server Failure"
Content-Length: 0
17/03/2017 18:23:52 - SendMsg from <sip:[email protected];tag3cx=219346e30389427992b857c8e6316ecc>;tag=0b0d3e16 to "Test Test"<sip:[email protected]>;tag=a4b199e334674aaeb3573a05a0442a3b
17/03/2017 18:23:52 - ~Target=PSTNline:3335492908@(Ln.10000@Patton Analog FXO)
17/03/2017 18:23:52 - Call(C:91) is terminated
17/03/2017 18:23:52 - Reported(Delete): SE:91.1{OnHook}
17/03/2017 18:23:52 - Issue: [Pres:0050; act=Open;0;33606]
17/03/2017 18:23:52 - [CM503020]: Call(C:91): Normal call termination. Call originator: Extn:0050. Reason: Server Failure
17/03/2017 18:23:52 - [CM503016]: Call(C:91): Attempt to reach <sip:[email protected]:5060> from Extn:0050 has failed. Reason: Server Failure
17/03/2017 18:23:52 - [Flow] Current call diversion path:[]
17/03/2017 18:23:52 - L:91.1[Extn:0050] failed to reach Line:10000>>3335492908, reason Server Failure
17/03/2017 18:23:52 - RerouteReq
17/03/2017 18:23:52 - SLA: 10000#0 'idle' -> 'idle'
17/03/2017 18:23:52 - ~CallLeg(C:91.2)
17/03/2017 18:23:52 - InviteADS::destroy:157
17/03/2017 18:23:52 - Call(C:91): Legs count: 1
17/03/2017 18:23:52 - Stop call record for leg L:91.2[Line:10000>>3335492908]
17/03/2017 18:23:52 - Removing leg L:91.2[Line:10000>>3335492908]
17/03/2017 18:23:52 - L:91.2[Line:10000>>3335492908]: Terminating targets, reason: SIP ;cause=503 ;text="Service Unavailable"
17/03/2017 18:23:52 - Leg L:91.2[Line:10000>>3335492908] is terminated: Cause: 503 Service Unavailable/INVITE from 192.168.0.31:5060
17/03/2017 18:23:52 - Ignored: SE:91.2{OnHook}
17/03/2017 18:23:52 - Issue: [Pres:10000; act=Open;0;33605]
17/03/2017 18:23:52 - StatusNotification: SE:91.2{OnHook}; Skip=0
17/03/2017 18:23:52 - L:91.2[Line:10000>>3335492908] got Terminated Recv 503/INVITE from 192.168.0.31:5060 tid=7776950710f1750b Call-ID=D1sdqmZoEdFpaUy4ObZe5g..:
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 192.168.0.30:5060;branch=z9hG4bK-524287-1---7776950710f1750b;rport=5060;received=192.168.0.30
To: <sip:[email protected]:5060>;tag=1216257094
From: "Test Test"<sip:192.168.0.30:5060>;tag=fc26cf6e
Call-ID: D1sdqmZoEdFpaUy4ObZe5g..
CSeq: 1 INVITE
Server: Patton SN4112 JO EUI 00A0BA0C9623 R6.T 2016-05-04 H323 SIP FXS FXO M5T SIP Stack/4.2.14.18
Reason: Q.850;cause=47;text="Resources unavailable, unspecified"
Content-Length: 0
17/03/2017 18:23:52 - Terminated from <sip:[email protected]:5060>;tag=1216257094 to "Test Test"<sip:192.168.0.30:5060>;tag=fc26cf6e; reason: Error
17/03/2017 18:23:52 - Issue: [Pres:10000; act=Open;0;33604]
17/03/2017 18:23:52 - ~Route=Dev:sip:[email protected]:5060
17/03/2017 18:23:52 - Call to T:Line:10000>>3335492908@[Dev:sip:[email protected]:5060] from L:91.1[Extn:0050] failed, cause: Cause: 503 Service Unavailable/INVITE from 192.168.0.31:5060
17/03/2017 18:23:52 - Device (1093958807) is used in 0 calls: []
17/03/2017 18:23:52 - L:91.2[Line:10000>>3335492908] got Failure: Failure Recv 503/INVITE from 192.168.0.31:5060 tid=7776950710f1750b Call-ID=D1sdqmZoEdFpaUy4ObZe5g..:
CSeq: 1 INVITE
Content-Length: 0
17/03/2017 18:23:52 - [CM503003]: Call(C:91): Call to <sip:[email protected]:5060> has failed; Cause: 503 Service Unavailable/INVITE from 192.168.0.31:5060
17/03/2017 18:23:52 - Session 68532 has failed in leg L:91.2[Line:10000>>3335492908] ; Cause: 503 Service Unavailable/INVITE from 192.168.0.31:5060
17/03/2017 18:23:52 - Failure from <sip:[email protected]:5060>;tag=1216257094 to "Test Test"<sip:192.168.0.30:5060>;tag=fc26cf6e
17/03/2017 18:23:52 - Endpoint Conf:7000 has refreshed contact <sip:[email protected]:5483>
17/03/2017 18:23:52 - Update registration: key=7000;contact=sip:[email protected]:5483;rinstance=4151dea4723e0e14; id=30
17/03/2017 18:23:52 - Dev(267391797):[sip:[email protected]:5483;rinstance=4151dea4723e0e14 / 7000]: PBX contact is local IP: <sip:[email protected]:5060>
17/03/2017 18:23:52 - Selected source IPv4 127.0.0.1 for destination 127.0.0.1
17/03/2017 18:23:52 - Updating device Dev(267391797):[sip:[email protected]:5483;rinstance=4151dea4723e0e14 / 7000] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=d69b2f72abf08d37 Call-ID=lI2VOqsBtd5BCLE5-l5U5Q..:
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---d69b2f72abf08d37;rport=5483
Max-Forwards: 70
Contact: <sip:[email protected]:5483;rinstance=4151dea4723e0e14>
To: "Conference Room7000:"<sip:[email protected]:5060>
From: "Conference Room7000:"<sip:[email protected]:5060>;tag=ada55818
Call-ID: lI2VOqsBtd5BCLE5-l5U5Q..
CSeq: 9918 REGISTER
Expires: 60
Proxy-Authorization: Digest username="7000",realm="3CXPhoneSystem",nonce="414d535958cc1ba751:22416bcaa500f3d8aa3f291ee10430d8",uri="sip:127.0.0.1:5060",response="657eb58735dda6659bbff808f2c1c597",algorithm=MD5
Supported: replaces
User-Agent: 3CX Conference Room
Content-Length: 0
17/03/2017 18:23:52 - Found 1 contact(s) for AOR sip:[email protected]
17/03/2017 18:23:52 - Update AOR sip:[email protected] with contact [<sip:[email protected]:5483;rinstance=4151dea4723e0e14>]
17/03/2017 18:23:52 - Caller "Conference Room7000:"<sip:[email protected]:5060>;tag=ada55818 has been authenticated successfully from IP 127.0.0.1
17/03/2017 18:23:51 - Endpoint ParkOrb:SP3 has refreshed contact <sip:[email protected]:5483>
17/03/2017 18:23:51 - Update registration: key=SP3;contact=sip:[email protected]:5483;rinstance=7a479ab34afd8948; id=17
17/03/2017 18:23:51 - Dev(1446339506):[sip:[email protected]:5483;rinstance=7a479ab34afd8948 / SP3]: PBX contact is local IP: <sip:[email protected]:5060>
17/03/2017 18:23:51 - Selected source IPv4 127.0.0.1 for destination 127.0.0.1
17/03/2017 18:23:51 - Updating device Dev(1446339506):[sip:[email protected]:5483;rinstance=7a479ab34afd8948 / SP3] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=e316385984d6ae0d Call-ID=1_1NkGNX_Glqq2H-EAqfxA..:
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---e316385984d6ae0d;rport=5483
Max-Forwards: 70
Contact: <sip:[email protected]:5483;rinstance=7a479ab34afd8948>
To: "SPSP3:"<sip:[email protected]:5060>
From: "SPSP3:"<sip:[email protected]:5060>;tag=48ebc12b
Call-ID: 1_1NkGNX_Glqq2H-EAqfxA..
CSeq: 2006 REGISTER
Expires: 300
Proxy-Authorization: Digest username="SP3",realm="3CXPhoneSystem",nonce="414d535958cc1ba623:6faf364f61dc325ef5d9f6fe19f920c6",uri="sip:127.0.0.1:5060",response="8e7830b2aaed71a8254a29ee9969a7a1",algorithm=MD5
Supported: replaces
Content-Length: 0
17/03/2017 18:23:51 - Found 1 contact(s) for AOR sip:[email protected]
17/03/2017 18:23:51 - Update AOR sip:[email protected] with contact [<sip:[email protected]:5483;rinstance=7a479ab34afd8948>]
17/03/2017 18:23:51 - Caller "SPSP3:"<sip:[email protected]:5060>;tag=48ebc12b has been authenticated successfully from IP 127.0.0.1
17/03/2017 18:23:48 - [CM503025]: Call(C:91): Calling T:Line:10000>>3335492908@[Dev:sip:[email protected]:5060] for L:91.1[Extn:0050]
17/03/2017 18:23:48 - Route to L:91.2[Line:10000>>3335492908] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=2544563dcf290007 Call-ID=D1sdqmZoEdFpaUy4ObZe5g..:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---2544563dcf290007;rport
Max-Forwards: 70
Contact: <sip:192.168.0.30:5060>
CSeq: 1 INVITE
Supported: replaces
Content-Length: 450
v=0
o=3cxPS 13660487501742080 20376886509043713 IN IP4 192.168.0.30
s=3cxPS Audio call
b=AS:84
t=0 0
a=X-nat:0
m=audio 42056 RTP/AVP 3 18 0 8 9 96
b=TIAS:64000
b=AS:84
a=rtcp:42057
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=fmtp:96 0-15
a=sendrecv
c=IN IP4 127.0.0.1
17/03/2017 18:23:48 - Device (1093958807) is used in 1 calls: [91]
17/03/2017 18:23:48 - OutCID: ''; OrigCID: ''; OutName: 'Test Test'
17/03/2017 18:23:48 - Outbound URI is used: sip:[email protected]:5060
17/03/2017 18:23:48 - L:91.2[Line:10000>>3335492908]: SLA slot is acquired: 10000#0 'idle'
17/03/2017 18:23:48 - SLA is not enabled for DN 10000
17/03/2017 18:23:48 - SLA is globally disabled
17/03/2017 18:23:48 - Legs count: 2
17/03/2017 18:23:48 - Added leg L:91.2[Line:10000>>3335492908]
17/03/2017 18:23:48 - [Flow] Call(C:91): making call from L:91.1[Extn:0050] to T:Line:10000>>3335492908@[Dev:sip:[email protected]:5060]
17/03/2017 18:23:48 - [CM503027]: Call(C:91): From: Extn:0050 ("Test Test" <sip:[email protected]:5060>) to T:Line:10000>>3335492908@[Dev:sip:[email protected]:5060]
17/03/2017 18:23:48 - [CM503004]: Call(C:91): Route 1: from L:91.1[Extn:0050] to T:Line:10000>>3335492908@[Dev:sip:[email protected]:5060]
17/03/2017 18:23:48 - Outbound CID reformat rule for DN:10000 is disabled (<Rules />)
17/03/2017 18:23:48 - Line limit check: Current # of calls for line Lc:10000(@Patton Analog FXO[<sip:[email protected]:5060>]) is 0; limit is 2
17/03/2017 18:23:48 - Call(C:91): Call from Extn:0050 to 3335492908 matches outbound rule 'patton_gateway'
17/03/2017 18:23:48 - [Flow] Call(C:91): has built target endpoint: Out#:>>Rule{patton_gateway}>>3335492908 for call from L:91.1[Extn:0050]
Qui una serie di screenshot delle configurazioni: https://goo.gl/photos/cHq1oPDrN85rpPZc9
Nessuna idea?
C'è qualcosa nella configurazione che non è corretta?
Grazie in anticipo per il supporto
Ciao Scusami se sono sparito, ma ho avuto un po da fare in questo periodo.
Probabilmente avrai già risolto i tuoi problemi ma ho notato alcune cose e vorrei fartele notare.
Io farei così, partirei a configurare il tutto da zero sia il centralino che l'interfaccia FXO della Patton.
Come primo interno non metterei il numero 0000 ma che ne so 1000 2000 ecc ecc, perchè potrebbe essere un prefisso, poi ho visto nella foto che hai messo, nella regola Patton Gateway non hai inserito i numeri di interni che possono accedere alla regola e non hai specificato con che numero deve iniziare la chiamata affinchè la regola venga soddisfatta.
Fammi sapere.
Ti auguro una buona serata.
Ciao.
Giuffro
Ciao Gianluca,
grazie per l'aiuto.
Ho risolto per quanto riguarda le telefonate in uscita, ora però ho un altro problema: non riesco a gestire le 2 telefonate simultanee che la linea supporta.
In pratica accade come segue:
1- Se non configuro alcuna DID (lascio semplicemente la regola di default impostata sul trunk), la prima chiamata va correttamente all'interno impostato.
Quando però arriva una seconda chiamata nella conversazione in corso si sente uno squillo (non sul telefono, proprio sulla linea), la qualità della telefonata si degrada, e a volte cade addirittura la linea.
2- Se configuro delle DID, (ad esempio imposto la DID "Linea 1" con l'ID 00000 per squillare sull'estensione "110", e una seconda DID "Linea 2" con l'ID 00001 per squillare sull'estensione "111") qualsiasi telefonata viene dirottata sulla linea 2, e di conseguenza sull'estensione 111.
La mia configurazione è la seguente
Patton 4112 collegato con 1 solo doppino sulla borchia Telecom NT1+ sulla porta TA a1/b1 (vedi http://web.mclink.it/MC4880/ISDN/Nt/domande.html)
Qualche suggerimento?
So che il mio post ti farà sorridere, ma sono veramente acerbo sulla telefonia, molto più efferato sulla sistemistica informatica.
Daniele
Ciao Daniele,
Mi sono andato a leggere in rete il manuale del Patton ed ho visto che ci sono tre modalità di funzionamento.
Intanto vorrei capire che versione hai del centralino se versione free o a pagamento. Se hai l' interfaccia Nt1+ era più opportuno acquistare un interfaccia da ISDN a Voip perché la qualità dell'audio è sicuramente migliore e non hai la doppia conversione, cioè da Isdn ad analogico e da analogico a Voip. Ricordati che se hai una versione free del software non riuscirai a far funzionare più di una linea telefonica cioè una sola linea del Patton, questa è una delle differenze fra la versione free e a pagamento.
Ciao a presto.
Gianluca Giuffrida.
Ciao Gianluca,
alla fine abbiamo optato per passare ad un Patton 4120, appunto per andare ad utilizzare il lato ISDN e non quello analogico.
Ora stiamo attendendo che arrivi il 4120 per procedere.
Grazie per il supporto
E' possibile sapere come hai risolto ?
Ho lo stesso problema e non ho ancora chiarito il motivo dell'anomalia
Grazie, ciao
malt25
