ho configurato un Patton usando il template predisposto su 3CX
nessuna modifica ai default
indirizzo IP statico al patton.. trunk registrato
le chiamate in entrata funzionano correttamente
un solo link analogico è presente, l'altro è scollegato
le chiamate in uscita falliscono tutte
il log si presenta così:
13-ott-2014 17:17:34.332 Leg L:185.1[Extn:208] is terminated: Cause: BYE from PBX
13-ott-2014 17:17:26.739 [CM503007]: Call(C:185): Extn:208 has joined, contact
13-ott-2014 17:17:26.738 L:185.4[EndCall:EndCall] has joined to L:185.1[Extn:208]
13-ott-2014 17:17:26.631 [CM503025]: Call(C:185): Calling T:EndCall:EndCall@[Dev:sip:[email protected]:40600;rinstance=5c25dfa16bf3c230] for L:185.1[Extn:208]
13-ott-2014 17:17:26.630 L:185.1[Extn:208] failed to reach Line:10004>>3480xxxxxx, reason Busy
13-ott-2014 17:17:26.630 Call to T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5061] from L:185.1[Extn:208] failed, cause: Cause: 486 Busy Here/INVITE from 192.168.10.228:5061
13-ott-2014 17:17:22.091 [CM503025]: Call(C:185): Calling T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5061] for L:185.1[Extn:208]
13-ott-2014 17:17:22.087 Call to T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061] from L:185.1[Extn:208] failed, cause: Cause: 502 Bad Gateway/INVITE from 192.168.10.228:5060
13-ott-2014 17:17:21.910 [CM503025]: Call(C:185): Calling T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061] for L:185.1[Extn:208]
13-ott-2014 17:17:21.861 [CM503027]: Call(C:185): From: Extn:208 ("Riccardo Grandi" ) to T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061]
13-ott-2014 17:17:21.861 [CM503004]: Call(C:185): Route 1: from L:185.1[Extn:208] to T:Line:10004>>3480xxxxxx@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061]
13-ott-2014 17:17:21.860 Call(C:185): Call from Extn:208 to 3480xxxxxx matches outbound rule 'Regola per Patton-A-Telecom'
13-ott-2014 17:17:21.860 [CM503001]: Call(C:185): Incoming call from Extn:208 to
boh
boh
