chiamte non entrano
gillsmit
29 Giugno 2015
Salve
Mi sta capitando questo problema da quando ho installato un router tplink sulla mia linea intecom (stessa cosa di eolo)
aperto porte sul mio router
5060 all
5061 tcp
9000-9015 udp
5090 tcp
3164 all
5000 tcp
80 all
tutte verso il mio pbx 192.168.1.100.
Ho usato il server stun di 3cx.
Le chiamate non vanno ne in entrata che in uscita.L interni sono tutti registrati.
questo e il log
21-lug-2016 09:05:44.827 [EC000001]: Connection with configuration server is lost
21-lug-2016 09:05:37.718 [EC100006]: Connection with Conference server is lost
21-lug-2016 09:05:35.576 [EC100004]: Connection with IVR server is lost
21-lug-2016 09:05:34.819 [CM504010]: Fax Service: Fax.888 unregistered contact sip:888:5100;user=phone
21-lug-2016 09:05:31.200 [CM504002]: Endpoint Ivr:EndCall: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:31.200 [CM504002]: Endpoint Ivr:HOL: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:31.199 [CM504002]: Endpoint Ivr:103: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:31.199 [CM504002]: Endpoint Ivr:102: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:31.195 [CM504002]: Endpoint Ivr:101: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:31.192 [CM504002]: Endpoint VMail:999: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:29.479 [EC100002] Connection with media server is lost
21-lug-2016 09:05:25.046 [CM504002]: Endpoint ParkOrb:*777: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:25.045 [CM504002]: Endpoint ParkOrb:*888: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:25.044 [CM504002]: Endpoint ParkOrb:*1: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:25.040 [CM504002]: Endpoint ParkOrb:*0: a contact is unregistered. Contact(s): []
21-lug-2016 09:05:24.975 [EC100007]: External application [SERVER-PC:0/QueueManager] is disconnected:
21-lug-2016 09:05:24.728 [EC100005]: Connection with Parking Orbit server is lost
21-lug-2016 09:01:36.516 Leg L:1.5[EndCall:EndCall] is terminated: Cause: BYE from PBX
21-lug-2016 09:01:36.516 [CM503008]: Call(C:1): Call is terminated
21-lug-2016 09:01:36.515 Leg L:1.1[Extn:600] is terminated: Cause: BYE from 192.168.1.101:5060
21-lug-2016 09:01:24.634 [CM503007]: Call(C:1): EndCall:EndCall has joined, contact <sip:[email protected]:40600>
21-lug-2016 09:01:24.632 [CM503007]: Call(C:1): Extn:600 has joined, contact <sip:[email protected]:5060>
21-lug-2016 09:01:24.628 L:1.5[EndCall:EndCall] has joined to L:1.1[Extn:600]
21-lug-2016 09:01:24.103 [CM503025]: Call(C:1): Calling T:EndCall:EndCall@[Dev:sip:[email protected]:40600;rinstance=86615ebc5f87c85a] for L:1.1[Extn:600]
21-lug-2016 09:01:24.044 L:1.1[Extn:600] failed to reach Line:10000>>03273241354, reason Forbidden
21-lug-2016 09:01:24.042 Leg L:1.4[Line:10000>>03273241354] is terminated: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:24.042 Call to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] from L:1.1[Extn:600] failed, cause: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:24.041 [CM503003]: Call(C:1): Call to <sip:[email protected]:5060> has failed; Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:17.635 Leg L:1.3[Line:10000>>03273241354] is terminated: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:17.635 [CM503025]: Call(C:1): Calling T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] for L:1.1[Extn:600]
21-lug-2016 09:01:17.624 Call to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] from L:1.1[Extn:600] failed, cause: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:17.623 [CM503003]: Call(C:1): Call to <sip:[email protected]:5060> has failed; Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:11.252 Leg L:1.2[Line:10000>>03273241354] is terminated: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:11.251 [CM503025]: Call(C:1): Calling T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] for L:1.1[Extn:600]
21-lug-2016 09:01:11.149 Call to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] from L:1.1[Extn:600] failed, cause: Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:11.061 [CM503003]: Call(C:1): Call to <sip:[email protected]:5060> has failed; Cause: 403 Forbidden/INVITE from 195.72.193.137:5060
21-lug-2016 09:01:05.858 Currently active calls - 1: [1]
21-lug-2016 09:01:04.192 [CM503025]: Call(C:1): Calling T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060] for L:1.1[Extn:600]
21-lug-2016 09:01:03.919 [CM503027]: Call(C:1): From: Extn:600 ("Mattia" <sip:[email protected]:5060>) to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060]
21-lug-2016 09:01:03.919 [CM503004]: Call(C:1): Route 3: from L:1.1[Extn:600] to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060]
21-lug-2016 09:01:03.918 Line limit check: Current # of calls for line Lc:10000(@Generic VoIP Provider -[<sip:[email protected]:5060>]) is 0; limit is 4
21-lug-2016 09:01:03.918 [CM503027]: Call(C:1): From: Extn:600 ("Mattia" <sip:[email protected]:5060>) to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060]
21-lug-2016 09:01:03.918 [CM503004]: Call(C:1): Route 2: from L:1.1[Extn:600] to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060]
21-lug-2016 09:01:03.918 [CM503004]: Call(C:1): Route 1: from L:1.1[Extn:600] to T:Line:10000>>03273241354@[Dev:sip:[email protected]:5060]
21-lug-2016 09:01:03.872 Line limit check: Current # of calls for line Lc:10000(@Generic VoIP Provider -[<sip:[email protected]:5060>]) is 0; limit is 4
21-lug-2016 09:01:03.764 Call(C:1): Call from Extn:600 to 03273241354 matches outbound rule 'Mattia Pintus'
21-lug-2016 09:01:03.612 [CM503001]: Call(C:1): Incoming call from Extn:600 to <sip:[email protected]:5060>
Hai provato a vedere se le porte vengono riconosciute aperte dall'esterno?
Prova con: http://www.yougetsignal.com/tools/open-ports/
allora provando tutte le porte dal link sono tutte chiuse ma la cosa assurda che da 3cx se faccio un controllo delle porte l unica che mi vede perta e la 3560
Dmitriy Tomatin
