Improvvisamente un 3cx regolarmente funzionante (da mesi), su hardware EeeBox con 5 telefoni grandstream BT200 , 2 telefoni Siemens a580, 1 gateway GrandStream x il collegamento alla rete urbana, 1 gateway Portech MSV-372 x il collegamento alla telefonia mobile, più linee Eutelia x il collegamento alla rete Voip (al momento non attive) ed in bridge con altri impianti 3cx (il centralino in questione è a Belgrado) non riesce più a registrare né ponti, né gateway, né interni.
Posto il log e attendo qualche suggerimento:
14:11:15.921 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:11:05.546 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:10:33.375 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:10:19.890 [CM504007]: Next attempt to register 52201@Xxxxxxx nnnnnnnnn is scheduled in 5 minute
14:10:19.890 [CM504005]: Registration failed for: 52201@Xxxxxxx nnnnnnnnn; Cause: 401 Unauthorized; warning: Noisy feedback tells: pid=21914 req_src_ip=213.198.240.196 req_src_port=5060 in_uri=sip:voip.eutelia.it:5060 out_uri=sip:voip.eutelia.it:5060 via_cnt==1; from IP:83.211.227.21:5060
14:10:19.484 [CM504003]: Sent registration request for 52201@Xxxxxxx nnnnnnnnn
14:10:00.843 [CM304002]: Tunnel is disconnected. Possibly remote end is not running.
14:09:26.984 [CM304002]: Tunnel is disconnected. Possibly remote end is not running.
14:09:19.015 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:08:46.875 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:08:14.343 [CM304002]: Tunnel is disconnected. Possibly remote end is not running.
14:07:37.703 [CM304002]: Tunnel is disconnected. Possibly remote end is not running.
14:07:32.687 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:07:00.546 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:06:49.843 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:06:17.703 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:06:07.359 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:05:35.218 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:05:24.625 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:05:19.437 [CM504007]: Next attempt to register 52201@Xxxxxxx nnnnnnnnn is scheduled in 5 minute
14:05:19.437 [CM504005]: Registration failed for: 52201@Xxxxxxx nnnnnnnnn; Cause: 401 Unauthorized; warning: Noisy feedback tells: pid=23392 req_src_ip=213.198.240.196 req_src_port=5060 in_uri=sip:voip.eutelia.it:5060 out_uri=sip:voip.eutelia.it:5060 via_cnt==1; from IP:83.211.227.21:5060
14:05:19.062 [CM504003]: Sent registration request for 52201@Xxxxxxx nnnnnnnnn
14:04:52.484 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:04:41.921 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:04:09.828 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:03:59.421 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:03:27.265 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:02:44.703 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:02:33.484 [CM504007]: Next attempt to register 52231@Ponte Verso nnnnnnnn is scheduled in 10 minutes
14:02:33.484 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 503 Remote end of tunnel is not connected; warning: Remote end of the bridge is not connected; from IP:127.0.0.1:5081
14:02:13.312 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:01:48.703 *** Connected to EeePcW:5482/CallManager at 127.0.0.1:5482 ***
14:01:48.625 [CM112000] Media Server is connected
14:01:41.125 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:01:30.218 [CM504005]: Registration failed for: 52231@Ponte Verso nnnnnnnn; Cause: 408 Request Timeout; internal
14:00:58.062 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:00:44.421 [CM504001]: Ext.802: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=1d4ad87a6a2c27c7/802]
14:00:44.406 [CM504001]: Ext.805: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=df667e3030f6e5c0/805]
14:00:44.375 [CM504001]: Ext.806: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=1067b3d71791bb30/806]
14:00:44.343 [CM504001]: Ext.804: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=6e133395c486291a/804]
14:00:44.328 [CM504001]: Ext.801: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=783ea335776827df/801]
14:00:44.250 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=bdf4d6f64f2c70b0/999]
14:00:30.984 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=64b6c355904883c3/*1]
14:00:30.968 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=2cfb2cc76d86ed15/*0]
14:00:29.000 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=a6f2b34663129485/704]
14:00:28.968 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=7f6a9b5239f0fd03/703]
14:00:28.921 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=5c43467412618455/702]
14:00:28.890 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=96ccdb7aaedea204/701]
14:00:28.828 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:[email protected]:40300;rinstance=16a6e3afd8205fd7/700]
14:00:19.046 [CM504007]: Next attempt to register 52201@Xxxxxxx nnnnnnnnn is scheduled in 5 minute
14:00:19.046 [CM504005]: Registration failed for: 52201@Xxxxxxx nnnnnnnnn; Cause: 401 Unauthorized; warning: Noisy feedback tells: pid=23388 req_src_ip=213.198.240.196 req_src_port=5060 in_uri=sip:voip.eutelia.it:5060 out_uri=sip:voip.eutelia.it:5060 via_cnt==1; from IP:83.211.227.21:5060
14:00:18.656 [CM504003]: Sent registration request for 52201@Xxxxxxx nnnnnnnnn
14:00:18.609 [CM504003]: Sent registration request for 52231@Ponte Verso nnnnnnnn
14:00:18.578 [CM504003]: Sent registration request for 52201@Xxxxxxx nnnnnnnnn
14:00:17.171 IP(s) added:[192.168.1.100]
13:59:56.781 [CM506005]: Public IP=213.198.240.196 is used for WAN communications through local interface with IP=192.168.1.100
13:59:56.640 [CM501006]: Default Local IP address: [192.168.1.100]
13:59:45.781 [CM501007]: *** Started Calls Controller thread ***
13:59:45.765 [CM501002]: Version: 7.1.7060.0
13:59:45.765 [CM501001]: Start 3CX PhoneSystem Call Manager
13:59:44.484 Unknown system [DBProvider] tries to connect!
13:59:44.406 [CM501009]: License Info: Loaded Succeeded
