Succede la stessa cosa a me, ma con il SIP Server, da interfaccia web risulta così:
| 3CX PhoneSystem 01 SIP Server | - | 00 | 0 | 0 | Arrestato |
Da shell invece risulta tutto avviato:
● 3CXEventNotificationManager.service - 3CX Event Notification Manager
Loaded: loaded (/lib/systemd/system/3CXEventNotificationManager.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:07 CEST; 54min ago
Main PID: 576 (CloudServicesWa)
Tasks: 25 (limit: 4915)
CGroup: /system.slice/3CXEventNotificationManager.service
└─576 /usr/lib/3cxpbx/CloudServicesWatcher -p /var/run/phonesystem/3CXEventNotificationManager.pid -c /var/lib/3cxpbx/Bin/CloudServicesWatcher.exe.config
lug 13 18:50:59 pbx systemd[1]: Starting 3CX Event Notification Manager...
lug 13 18:51:07 pbx systemd[1]: Started 3CX Event Notification Manager.
● 3CXCfgServ01.service - 3CX PhoneSystem Configuration Service
Loaded: loaded (/lib/systemd/system/3CXCfgServ01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:09 CEST; 54min ago
Main PID: 792 (3CXSLDBServ)
Tasks: 17 (limit: 4915)
CGroup: /system.slice/3CXCfgServ01.service
└─792 /usr/sbin/3CXSLDBServ -n -p /var/run/phonesystem/3CXCfgServ01.pid -o /var/lib/3cxpbx/Bin/Objects.cls -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini
lug 13 18:51:08 pbx systemd[1]: Starting 3CX PhoneSystem Configuration Service...
lug 13 18:51:09 pbx systemd[1]: Started 3CX PhoneSystem Configuration Service.
● 3CXCallFlow01.service - 3CX PhoneSystem 01 CallFlow Server
Loaded: loaded (/lib/systemd/system/3CXCallFlow01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:18 CEST; 54min ago
Main PID: 914 (3CXCallFlow)
Tasks: 15 (limit: 4915)
CGroup: /system.slice/3CXCallFlow01.service
└─914 /usr/lib/3cxpbx/3CXCallFlow -p /var/run/phonesystem/3CXCallFlow01.pid /var/lib/3cxpbx/Bin/config.json
lug 13 18:51:15 pbx systemd[1]: Starting 3CX PhoneSystem 01 CallFlow Server...
lug 13 18:51:18 pbx systemd[1]: Started 3CX PhoneSystem 01 CallFlow Server.
● 3CXAudioProvider01.service - 3CX PhoneSystem 01 Audio Provider Server
Loaded: loaded (/lib/systemd/system/3CXAudioProvider01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:10 CEST; 54min ago
Main PID: 805 (3CXAudioProvide)
Tasks: 6 (limit: 4915)
CGroup: /system.slice/3CXAudioProvider01.service
└─805 /usr/sbin/3CXAudioProvider -n -p /var/run/phonesystem/3CXAudioProvider01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini
lug 13 18:51:09 pbx systemd[1]: Starting 3CX PhoneSystem 01 Audio Provider Server...
lug 13 18:51:10 pbx systemd[1]: Started 3CX PhoneSystem 01 Audio Provider Server.
● 3CXIVR01.service - 3CX PhoneSystem 01 IVR Server
Loaded: loaded (/lib/systemd/system/3CXIVR01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:15 CEST; 54min ago
Main PID: 916 (3CXIVR)
Tasks: 7 (limit: 4915)
CGroup: /system.slice/3CXIVR01.service
└─916 /usr/sbin/3CXIVR -n -p /var/run/phonesystem/3CXIVR01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini
lug 13 18:51:15 pbx systemd[1]: Starting 3CX PhoneSystem 01 IVR Server...
lug 13 18:51:15 pbx systemd[1]: Started 3CX PhoneSystem 01 IVR Server.
● 3CXSystemService01.service - 3CX PhoneSystem 01 System Server
Loaded: loaded (/lib/systemd/system/3CXSystemService01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:13 CEST; 54min ago
Main PID: 801 (3cxSystemServic)
Tasks: 32 (limit: 4915)
CGroup: /system.slice/3CXSystemService01.service
└─801 /usr/lib/3cxpbx/3cxSystemService -p /var/run/phonesystem/3CXSystemService01.pid /var/lib/3cxpbx/Bin
lug 13 18:51:09 pbx systemd[1]: Starting 3CX PhoneSystem 01 System Server...
lug 13 18:51:13 pbx systemd[1]: Started 3CX PhoneSystem 01 System Server.
● 3CXPhoneSystemMC01.service - 3CX PhoneSystem 01 Management Console
Loaded: loaded (/lib/systemd/system/3CXPhoneSystemMC01.service; enabled; vendor preset: enabled)
Main PID: 804 (3CXManagementCo)
Tasks: 42 (limit: 4915)
CGroup: /system.slice/3CXPhoneSystemMC01.service
└─804 /usr/lib/3cxpbx/3CXManagementConsole --pid /var/run/phonesystem/3CXPhoneSystemMC01.pid -p /var/lib/3cxpbx/Instance1/Data/Http/webroot
lug 13 18:51:09 pbx systemd[1]: Starting 3CX PhoneSystem 01 Management Console...
lug 13 18:51:18 pbx systemd[1]: Started 3CX PhoneSystem 01 Management Console.
lug 13 18:52:29 pbx sudo[1102]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/bin/systemctl start 3CXPhoneSystem01
lug 13 18:52:29 pbx sudo[1102]: pam_unix(sudo:session): session opened for user root by (uid=0)
lug 13 18:54:22 pbx sudo[1251]: phonesystem : TTY=unknown ; PWD=/var/lib/3cxpbx ; USER=root ; COMMAND=/bin/systemctl start 3CXPhoneSystem01
lug 13 18:54:22 pbx sudo[1251]: pam_unix(sudo:session): session opened for user root by (uid=0)
● 3CXTunnel01.service - 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy
Loaded: loaded (/lib/systemd/system/3CXTunnel01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:01 CEST; 54min ago
Main PID: 577 (3CXTunnel)
Tasks: 8 (limit: 4915)
CGroup: /system.slice/3CXTunnel01.service
└─577 /usr/sbin/3CXTunnel -n -p /var/run/phonesystem/3CXTunnel01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini
lug 13 18:50:59 pbx systemd[1]: Starting 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy...
lug 13 18:51:01 pbx systemd[1]: Started 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy.
● 3CXQueueManager01.service - 3CX PhoneSystem 01 Queue Manager Server
Loaded: loaded (/lib/systemd/system/3CXQueueManager01.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-07-13 18:51:17 CEST; 54min ago
Main PID: 915 (TcxQMsrv)
Tasks: 21 (limit: 4915)
CGroup: /system.slice/3CXQueueManager01.service
└─915 /usr/lib/3cxpbx/TcxQMsrv -p /var/run/phonesystem/3CXQueueManager01.pid /var/lib/3cxpbx/Bin/config.json
lug 13 18:51:15 pbx systemd[1]: Starting 3CX PhoneSystem 01 Queue Manager Server...
lug 13 18:51:17 pbx systemd[1]: Started 3CX PhoneSystem 01 Queue Manager Server.
● 3CXMediaServer.service - 3CX PhoneSystem Media Server
Loaded: loaded (/lib/systemd/system/3CXMediaServer.service; enabled; vendor preset: enabled)
Main PID: 616 (3CXMediaServer)
CGroup: /system.slice/3CXMediaServer.service
└─616 /usr/sbin/3CXMediaServer -n -p /var/run/phonesystem/3CXMediaServer.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini -m /var/lib/3cxpbx/Bin/3cxmediaserver.ini
lug 13 18:51:00 pbx systemd[1]: Starting 3CX PhoneSystem Media Server...
lug 13 18:51:01 pbx systemd[1]: Started 3CX PhoneSystem Media Server.
