Sto riscontrando problemi con le chiamate in uscita, o meglio queste proprio non vengono effettuate, dopo qualche secondo cade la linea.
Ho installato la versione free per fare un po di test.
Il gateway è un patton 4112 2 FXO
Vi riporto il log server della chiamata in uscita.
Voglio precisare che le chiamate in entrata funzionano.
21-mag-2014 01:20:52.370 Leg L:2.1[Extn:11] is terminated: Cause: BYE from PBX
21-mag-2014 01:20:52.320 [CM503020]: Call(C:2): Normal call termination. Call originator: Extn:11. Reason: Busy
21-mag-2014 01:20:52.320 L:2.1[Extn:11] failed to reach Line:10000>>3409343235, reason Busy
21-mag-2014 01:20:52.320 Leg L:2.2[Line:10000>>3409343235] is terminated: Cause: 486 Busy Here/INVITE from 192.168.1.101:5060
21-mag-2014 01:20:52.320 Call to T:Line:10000>>3409343235@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061] from L:2.1[Extn:11] failed, cause: Cause: 486 Busy Here/INVITE from 192.168.1.101:5060
21-mag-2014 01:20:52.320 [CM503003]: Call(C:2): Call to has failed; Cause: 486 Busy Here/INVITE from 192.168.1.101:5060
21-mag-2014 01:20:47.820 [CM503025]: Call(C:2): Calling T:Line:10000>>3409343235@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061] for L:2.1[Extn:11]
21-mag-2014 01:20:47.771 [CM503027]: Call(C:2): From: Extn:11 ("Mario Rossi" ) to T:Line:10000>>3409343235@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061]
21-mag-2014 01:20:47.771 [CM503004]: Call(C:2): Route 1: from L:2.1[Extn:11] to T:Line:10000>>3409343235@[Dev:sip:[email protected]:5060,Dev:sip:[email protected]:5061]
21-mag-2014 01:20:47.771 Line limit check: Current # of calls for line Lc:10001(@patton[]) is 0; limit is 1
21-mag-2014 01:20:47.771 Line limit check: Current # of calls for line Lc:10000(@patton[]) is 0; limit is 1
21-mag-2014 01:20:47.771 Call(C:2): Call from Extn:11 to 3409343235 matches outbound rule 'TEST'
21-mag-2014 01:20:47.771 [CM503001]: Call(C:2): Incoming call from Extn:11 to
21-mag-2014 01:20:41.019 Leg L:1.1[Line:10000
