Chiamate in uscita con patton 4114
ho configurato il mio patton 4114 con la versione 9 del 3CX.
Le chiamate in ingresso arrivano tranquillamente quelle in uscita non ne vogliono sapere?
Di seguito un pezzo di log:
15:49:18.578 [CM306003]: SIP IP:port mapping (79.28.104.118:8019) resolved by STUN server 75.101.138.128:3478 differs from the one (79.28.104.118:2476 resolved by STUN server 178.238.134.190
15:49:18.578 [CM306003]: SIP IP:port mapping (79.28.104.118:4679) resolved by STUN server 96.9.132.83:3478 differs from the one (79.28.104.118:2476 resolved by STUN server 178.238.134.190
15:49:18.484 [CM306003]: SIP IP:port mapping (79.28.104.118:4679) resolved by STUN server 96.9.132.83:3478 differs from the one (79.28.104.118:8019 resolved by STUN server 75.101.138.128
15:49:18.343 [CM506003]: Resolved SIP external IP:port has changed to (79.28.104.118:4679) on Transport 192.168.0.6:5060
15:49:18.187 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.6:5060
15:35:22.875 [CM503020]: Normal call termination. Reason: Not found
15:35:22.875 [CM503016]: Call(21): Attempt to reach failed. Reason: Not Found
15:35:22.875 [CM503014]: Call(21): No known route to target:
15:35:22.875 [CM503010]: Making route(s) to
15:35:22.875 [CM505001]: Ext.103: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.2.26] PBX contact: [sip:[email protected]:5060]
15:35:22.843 [CM503001]: Call(21): Incoming call from Ext.103 to
15:34:27.781 [CM503020]: Normal call termination. Reason: Not found
15:34:27.781 [CM503016]: Call(20): Attempt to reach failed. Reason: Not Found
15:34:27.781 [CM503014]: Call(20): No known route to target:
15:34:27.781 [CM503010]: Making route(s) to
15:34:27.781 [CM505001]: Ext.103: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.2.2.26] PBX contact: [sip:[email protected]:5060]
15:34:27.750 [CM503001]: Call(20): Incoming call from Ext.103 to
15:29:18.359 [CM306003]: SIP IP:port mapping (79.28.104.118:6891) resolved by STUN server 75.101.138.128:3478 differs from the one (79.28.104.118:7907 resolved by STUN server 178.238.134.190
15:29:18.359 [CM306003]: SIP IP:port mapping (79.28.104.118:8241) resolved by STUN server 96.9.132.83:3478 differs from the one (79.28.104.118:7907 resolved by STUN server 178.238.134.190
15:29:18.281 [CM306003]: SIP IP:port mapping (79.28.104.118:8241) resolved by STUN server 96.9.132.83:3478 differs from the one (79.28.104.118:6891 resolved by STUN server 75.101.138.128
15:29:18.125 [CM506003]: Resolved SIP external IP:port has changed to (79.28.104.118:8241) on Transport 192.168.0.6:5060
15:29:17.968 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.0.6:5060
Senza un dettaglio della configurazione è difficile capire cosa stia succedendo.
Serve una descrizione degli IP utilizzati ed un log di una chiamata fatta indicando l'interno da cui la stessa viene effettuata ed il numero chiamato. Probabilmente però le regole di uscita non sono correttamente impostate.
Hai provato almeno a settare delle regole in uscita dall'apposita sezione?
Dal log sembrerebbe che il centralino non sa proprio cosa fare della tua chiamata in uscita perché non sa dove instradarla...
