buongiorno, ho da poco istallato questo centralino, e collegato ad in linksys spa400 "due linee analogiche fastweb"
non riesco a far funzionare le chiamate in uscita, mentre in entrata funziona tutto perfettamente
ho corretto il numero con degli 0 e ho provato ad anteporre 0 o 1 per chiamare
attendo un vostro aiuto
questo e' il log
11-nov-2012 22:42:02.408 Leg L:73.1[Extn:10] is terminated: Cause: BYE from PBX
11-nov-2012 22:42:02.380 [CM503020]: Call(C:73): Normal call termination. Call originator: Extn:10. Reason: Not available
11-nov-2012 22:42:02.380 L:73.1[Extn:10] failed to reach Out#:>>Rule{Regola per spa400}>>#0000000000, reason Temporarily Unavailable
11-nov-2012 22:42:02.354 [CM503026]: Call(C:73): Route 1 to PSTNlinespa400 is not active (Busy/Not registered)
11-nov-2012 22:42:02.354 Call(C:73): from L:73.1[Extn:10]: There are no available outbound lines on Trunk 'PSTNlinespa400' at this time. First line: 10300
11-nov-2012 22:42:02.352 [CM303003]: There are no available outbound lines on gateway spa400 at this time. First line: Lc:10300(@spa400[])
11-nov-2012 22:42:02.352 Line limit check: Current # of calls for line Lc:10300(@spa400[]) is 0; limit is 2
11-nov-2012 22:42:02.352 Call(C:73): Call from Extn:10 to #0000000000 matches outbound rule 'Regola per spa400'
11-nov-2012 22:42:02.351 [CM503001]: Call(C:73): Incoming call from Extn:10 to
questo e' il log
