configurazione PAP2T per invio FAX
Salve Ho un problema nel configurare correttamente un PAP2T per l'invio dei FAX.
il provider è FASTWEB con 2 linee ISDN ed un gateway Patton4554
Il PAP2T funziona perfettamente con un telefono analogico ma appena effettua una chiamata ad un fax la chiamamata viene interrotta appena viene ricevuto il tono fax e chiusa dopo pochi secondi.
Se si configura l'interno con "Supporta Re-Invite" la chiamata viene istantanemante chiusa all'arrivo del tono fax
la log e' la seguente:
16:51:26.285 [CM503008]: Call(409): Call is terminated
16:51:01.331 Currently active calls - 1: [409]
16:50:43.128 [MS210003] C:409.3:Answer provided. Connection(transcoding mode[unsecure]):192.168.2.10:7016(7017)
16:50:43.128 Remote SDP is set for legC:409.3
16:50:41.581 [MS210003] C:409.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.2.10:7012(7013)
16:50:41.581 [MS210001] C:409.3:Answer received. RTP connection[unsecure]: 192.168.2.200:5108(5109)
16:50:41.581 Remote SDP is set for legC:409.3
16:50:41.378 [MS210002] C:409.3:Offer provided. Connection(transcoding mode): 192.168.2.10:7016(7017)
16:50:41.378 [MS210000] C:409.1:Offer received. RTP connection: 192.168.2.210:16440(16441)
16:50:41.363 Remote SDP is set for legC:409.1
16:50:41.097 [CM503007]: Call(409): Device joined: sip:[email protected]:5060
16:50:41.097 Session 150804 of leg C:409.1 is confirmed
16:50:41.081 [CM503007]: Call(409): Device joined: sip:[email protected]:5060
16:50:41.050 [MS210003] C:409.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.2.10:7012(7013)
16:50:41.003 [MS210001] C:409.3:Answer received. RTP connection[unsecure]: 192.168.2.200:5108(5109)
16:50:41.003 Remote SDP is set for legC:409.3
16:50:37.331 [CM503002]: Call(409): Alerting sip:[email protected]:5060
16:50:32.003 [CM503025]: Call(409): Calling Unknown:08119363872@(Ln.10001@Patton4554)@[Dev:sip:[email protected]:5060]
16:50:32.003 [MS210002] C:409.3:Offer provided. Connection(transcoding mode): 192.168.2.10:7016(7017)
16:50:31.988 [CM503003]: Call(409): Call to sip:[email protected]:5062 has failed; Cause: 503 Service Unavailable; from IP:192.168.2.200:5062
16:50:31.253 Currently active calls - 1: [409]
16:50:27.800 [CM503025]: Call(409): Calling Unknown:08119363872@(Ln.10001@Patton4554)@[Dev:sip:[email protected]:5062]
16:50:27.800 [MS210002] C:409.2:Offer provided. Connection(transcoding mode): 192.168.2.10:7014(7015)
16:50:27.769 [CM503004]: Call(409): Route 1: Unknown:08119363872@(Ln.10001@Patton4554)@[Dev:sip:[email protected]:5062,Dev:sip:[email protected]:5060]
16:50:27.769 [CM503010]: Making route(s) to
16:50:27.769 [MS210000] C:409.1:Offer received. RTP connection: 192.168.2.210:16440(16441)
16:50:27.769 Remote SDP is set for legC:409.1
16:50:27.769 [CM505001]: Ext.20: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/PAP2T-5.1.6(LS)] PBX contact: [sip:[email protected]:5060]
16:50:27.738 [CM503001]: Call(409): Incoming call from Ext.20 to
16:50:27.738 [CM500002]: Info on incoming INVITE:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.2.210:5060;branch=z9hG4bK-7f6138f7
Max-Forwards: 70
Contact: "20"
To:
Call-ID: 3951d2c2-cd203d6a @192.168.2.210
CSeq: 102 INVITE
Expires: 240
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Proxy-Authorization: Digest username="20",realm="3CXPhoneSystem",nonce="414d535c032946c373:4b29a52d5e3d6e1a78d043a254bbc61d",uri="sip:[email protected]",algorithm=MD5,response="40bd116ad93dc76116005bc3f370da80"
Supported: x-sipura, replaces
User-Agent: Linksys/PAP2T-5.1.6(LS)
Content-Length: 0
Ho provato molti tipi di configurazioine ma senza successo:
Dovresti seguire le linee guida per la configurazione come ATA FAX dello SPA-3102. Temo però che il PAP2T sia piuttosto limitato nella gestione del T38 rispetto agli SPA-3102 e 2102 che funzionano correttamente da questo punto di vista.
Dovresti provare a disabilitare il Re-invite e Replace (ll PBX deliver audio va ovviamente sempre disabilitao quando utilizzato T38) e a modificare i parametri di Jitter e T38. Credo che però la soluzione più conveniente ed affidabile sia quella di impiegare uno SPA-2102/3102 al posto del PAP2T. Lo Spa 2102 si configura esattamente come il 3102 ma ha il vantaggio, oltre che di costare meno, di fornire 2 Porte FXS idonee ad essere utilizzate come due porte separate per la connessione di FAX tradizionali.
