Configurazione Patton SmartNode 4554
Salve a tutti,
ho provato a configurare il Patton SmartNode 4554 su una postazione Windows XP con 3CX SB ver. 6 per gestire 2 linee ISDN, al contrario di quanto viene indicato nelle guide, al termine della configurazione non era presente il pulsante per il relativo salvataggio: qualcuno saprebbe darmi qualche informazione in merito alla configurazione oppure potrebbe postare una configurazione base del Patton 4554?
Davide
# SN4554/2BIS/EUI #
# R4.2 2007-09-19 SIP #
# 1970-01-01T03:10:04 #
# SN/00A0BA039D46 #
# Generated configuration file #
cli version 3.20
webserver port 80 language en
system
ic voice 0
low-bitrate-codec g729
system
clock-source 1 bri 0 0
profile ppp default
profile call-progress-tone defaultDialtone
pause 1 1000
pause 2 200
profile call-progress-tone defaultBusytone
play 1 200 425 -7
pause 2 200
profile tone-set default
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
fax transmission 1 relay t38-udp
profile pstn default
profile sip default
no autonomous-transitioning
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
ipaddress IP DEL PATTON 255.255.255.0
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
context cs switch
no digit-collection timeout
no digit-collection terminating-char
no address-completion timeout
national-prefix 0
international-prefix 00
routing-table called-e164 RT_ISDN_TO_SIP_0
route T2 dest-interface IF_SIP_0 MP_REM_CLIR
routing-table called-e164 RT_ISDN_TO_SIP_1
route T2 dest-interface IF_SIP_1 MP_REM_CLIR
mapping-table calling-pi to calling-e164 MP_REM_CLIR
map restricted to ""
interface isdn IF_ISDN_0
route call dest-table RT_ISDN_TO_SIP_0
interface isdn IF_ISDN_1
route call dest-table RT_ISDN_TO_SIP_1
interface sip IF_SIP_0
bind gateway GW_SIP_0
service default
route call dest-interface IF_ISDN_0
early-connect
early-disconnect
remote-party-id called-party
address-translation outgoing-call request-uri user-part fix 10003 host-part to-header target-param none
address-translation incoming-call called-e164 request-uri
interface sip IF_SIP_1
bind gateway GW_SIP_1
service default
route call dest-interface IF_ISDN_1
early-connect
early-disconnect
address-translation outgoing-call request-uri user-part fix 10004 host-part to-header target-param none
context cs switch
no shutdown
gateway sip GW_SIP_0
bind interface IF_IP_LAN router
service default
domain IP DEL SERVER
defaultserver manual IP DEL SERVER loose-router
registration-lifetime 300
registration manual IP DEL SERVER
user 10003 authenticate password ySyWxUvSc/c= encrypted default register
no shutdown
gateway sip GW_SIP_1
call-signaling-port 5062
service default
user 10004 authenticate password 9CS6/5Fhrd0= encrypted default register
no shutdown
port ethernet 0 0
encapsulation ip
no shutdown
port bri 0 0
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bchan-number-order ascending
encapsulation cc-isdn
bind interface IF_ISDN_0 switch
port bri 0 0
no shutdown
port bri 0 1
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bind interface IF_ISDN_1 switch
port bri 0 1
no shutdown
Copia il contenuto del post precedente in un file txt e con trova e sostituisci ti vai a cambiare i dati in verde con i tuoi.
10003 E 10004 sono gli identificativi della linea (in genere ti vengono assegnati in automatico dal 3cx, io avendo già 3 provider voip configurati 10000,10001,10002 mi vengono assegnati 10003 e 10004) purtroppo non riesci a modificare semplicemente sostituendo le voci 10003 e 10004 (come avviene per l'indirizzo ip) perché le password associate "10003" e "10004" sono criptate "user 10003 authenticate password ySyWxUvSc/c= encrypted default register
", per far andare tutto liscio magari puoi creare 3 provider fittizi, oppure ti devi cambiare questa parte della configurazione direttamente sul patton, oppure puoi sostituire "10003" e "10004" con le linee che 3cx ti ha assegnato, ed eventualmente impostare su 3cx "10003" (per il primo canale) e "10004" (per il secondo canale) come password di autenticazione (forse questo è il metodo più rapido).
Spero di esserti stato utile, fammi sapere. :lol:
lklocke
