Disponibile Nuova Buid 7.1.7139 22 Maggio 2009
eurylink.com
Gold Partner
Disponibile la nuova Build 7.1.7139 22 del Maggio 2009
Note sulla nuova release (in inglese):
If you are uninstalling 3CX Phone System version v7.1 6589 and you make heavy use of the 3CX Tunnel Service, it may happen that the 3CX
Phone System service will not stop in a timely fashion. To proceed with the installation open Task manager (right click on the task bar, Task Manager), right click on the 3CXPhoneSystem.exe process, and Click End Process. The installation will then proceed automatically as usual.
* Added: Template of actio.pl - Polish provider
* Added: Snom 820 template for provisioning
* Added: Parameter to enable / disable VmAIL pin VMPINREQUIRED 1= ON , 0=OFF
* Fixed: Improved logging notifications in PBX Logs
* Fixed: Added a cache limit in Tunnel to reduce memory usage in largerenvironments
* Fixed: Tunnel not starting when port is in use
* Fixed: Stuck calls in call assistant server in particular situations
* Fixed: Permissions in the viewing of extensions in different membergroups has been improved
* Fixed: Buffer UDP FAX Outgoing Faxes over Patton gateways ISDN 4960
* Fixed: Control size of Fax Log file
* Fixed: Parameter Table Validation for duplicate parameters
* Fixed: Removed excessive Make call registrations in server status log
* Fixed: Call History Service handling of unterminated calls
* Fixed: Call History Service handling of Call repostings file
* Fixed: Backup and restore of Call logs for Netherlands entry (relatedto formatting of country name)
* Fixed: Management Console: Stuck calls in Management console in Ringing State
* Fixed: Management console translation file for SIP FIELD.
* Fixed: Management console - removed unnecessary updates in active calls page
* Fixed: Management console download link for PBX manual 7.1
* Fixed: Voip Providers -> TCP transport for Broadvox
* Fixed: Voip Providers Added parameter for Voip Providers remote partyid : Calling party : user part == Caller Name
* Fixed: Date and Time Conversion in Voicemail.
LINK PER IL DOWNLOAD
Postare qui per favore eventuali anomalie/migliorie riscontrate.
Non so se è una anomali riscontrata da altri, e non solo in questa ultima Build, ma ultimamente cone le versioni 7.1.xxx quando scrivo nell'interfaccia web di configurazione, in ogni campo il cursore salta indietro dopo qualche carattere e quindi o cancello pezzi già scritti o scrivo cose prive di senso essendo il cursore posizionato in mezzo ad una parola... Digitando abbastanza velocemente è un problema abbastanza fastidioso, considerando che si ripete anche più volte sullo stesso campo.
Qualcun altro ha notato la cosa?
Usa Firefox per accedere a 3CX. Lascia perdere Explorer 7 che da un sacco di problemi e rallentamenti (per via dell'interfacia di sviluppo scelta da 3CX).
