Eutelia chiamate in entrata
Ciao a tutti, non ho problemi per le chiamate in entrata, mentre quelle in uscita non riesco a farle, e non capisco perchè.
Allego il log:
11:20:13.066 [CM503020]: Normal call termination. Reason: Forbidden
11:20:13.066 [CM503016]: Call(4): Attempt to reach failed. Reason: Forbidden
11:20:13.056 [CM503003]: Call(4): Call to sip:[email protected]:5060 has failed; Cause: 403 From user does not match authenticated user; warning: Noisy feedback tells: pid=2513 req_src_ip=85.88.202.118 req_src_port=5060 in_uri=sip:[email protected]:5060 out_uri=sip:[email protected]:5060 via_cnt==1; from IP:83.211.227.21:5060
11:20:12.836 [CM503025]: Call(4): Calling VoIPline:800022022@(Ln.10001@Eutelia)@[Dev:sip:[email protected]:5060]
11:20:12.806 [CM503004]: Call(4): Route 1: VoIPline:800022022@(Ln.10001@Eutelia)@[Dev:sip:[email protected]:5060]
11:20:12.806 [CM503010]: Making route(s) to
11:20:12.806 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [fring] PBX contact: [sip:[email protected]:5060]
11:20:12.796 [CM503001]: Call(4): Incoming call from Ext.100 to
11:18:02.385 [CM503003]: Call(3): Call to sip:[email protected] has failed; Cause: 487 Request Cancelled; from IP:89.186.92.102:55818
11:18:02.254 [CM503008]: Call(3): Call is terminated
11:17:55.634 [CM503025]: Call(3): Calling Ext:Ext.100@[Dev:sip:[email protected]:55818;transport=udp]
11:17:55.574 [CM503004]: Call(3): Route 1: Ext:Ext.100@[Dev:sip:[email protected]:55818;transport=udp]
11:17:55.554 [CM503010]: Making route(s) to
11:17:55.554 [CM505003]: Provider:[Eutelia] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-SIPGateway/IOS-12.x] PBX contact: [sip:[email protected]:5060]
11:17:55.534 [CM503001]: Call(3): Incoming call from 3487391212@(Ln.10001@Eutelia) to
11:17:55.373 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:100
10:55:42.959 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:[email protected]:55818;transport=udp/100]
Spero in un aiuto.
Giovanni
Verifica Firewall e Router ed assicurati di utilizzare il template dedicato ad eutelia che puoi scaricare dal wiki di 3CX.
Controlla che le porte siano aperte correttamente e che il router sia adatto all'impiego SIP.
Ovviamente devi essere in possesso di ADSL IP statico altrimenti la situazione si complica ulteriormente.
@eurylink.com wrote:Verifica Firewall e Router ed assicurati di utilizzare il template dedicato ad eutelia che puoi scaricare dal wiki di 3CX.
mille grazie, non usavo il templato giusto. Risolto, ammetto che è veramente funzionale come centralino.
Giovanni
