Fax server
volevo sfruttare la possibilità di inviare fax attraverso il fax server inserito in 3cx (credo che sia "stupido" stampare un foglio word e poi inserirlo nel fax, quando tutto questo può essere fatto in maniera "automatica").
Ho delle macchine con xp, ho istallato la console di servizio fax e la beta del serverfax di 3cx come indicato sul sito.
Se provo stampare e quindi ad inviare un fax sulla console mi viene riferito che lo "stato esteso" è "Errore irreversibile", mentre il log del server è:
10:43:32.546 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
10:33:53.984 StunClient::onInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.223:5061
10:33:08.234 FaxCfg::updateContact [CM504009]: Fax Service: changed contact to sip:[email protected]:5100;user=phone
10:33:02.687 FaxCfg::updateContact [CM504009]: Fax Service: changed contact to sip:[email protected]:5061
10:23:18.671 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:[email protected]:5061 with contact sip:[email protected]:5100;user=phone
10:13:53.906 StunClient::onInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.223:5061
10:13:31.000 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
10:09:57.890 Call::Terminate [CM503008]: Call(7): Call is terminated
10:09:57.890 CallCtrl::onIncomingCall [CM502001]: Source info: From: 7; To: [sip:[email protected]:5061];tag=1C83[sip:081479620 @192.168.1.223:5061;user=phone]
10:09:57.890 CallCtrl::onIncomingCall [CM503013]: Call(7): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 081479620 @192.168.1.223:5061 tid=-5E6F-27 cseq=INVITE [email protected]:5100 / 32 from(wire)
10:03:24.578 FaxCfg::updateContact [CM504009]: Fax Service: changed contact to sip:[email protected]:5100;user=phone
10:03:18.656 FaxCfg::updateContact [CM504009]: Fax Service: changed contact to sip:[email protected]:5061
09:59:52.406 Call::Terminate [CM503008]: Call(6): Call is terminated
09:59:52.406 CallCtrl::onIncomingCall [CM502001]: Source info: From: 6; To: [sip:[email protected]:5061];tag=2FC3[sip:081479620 @192.168.1.223:5061;user=phone]
09:59:52.406 CallCtrl::onIncomingCall [CM503013]: Call(6): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 081479620 @192.168.1.223:5061 tid=-3801-1E cseq=INVITE [email protected]:5100 / 25 from(wire)
09:53:52.546 StunClient::onInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.223:5061
09:53:35.015 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:[email protected]:5061 with contact sip:[email protected]:5100;user=phone
Dove 88 credo che sia la porta del fax, 192.168.1.223 l'ip della macchiana che ospita 3cx e 5061 la porta che utilizzo (al posto della 5060 che uso per altro).
Non vorrei montare un modem fax.
Avete suggerimenti o esperienze da segnalare?
Su che sistema operativo è installato il Server Fax ?
Ciao, Xp pro e se può servire ho 2 linkys spa 3101 e 2101
Per inviare Fax ti server il Fax Server di Microsoft che però è disponibile solo su Windows Server 2003 o 2008. Su Xp c'è solo il client.
hai qlc suggerimento?
No purtroppo. Con Xp nom è possibile. Valuta eventualmente l'upgrade a windows server se ritieni ne valga la pena.
