- 17 Gennaio 2015
Tutto configurato tutto funzionante per una decina di ore, da questa mattina i miei interlocutori non mi sentono, sia che provi dai numeri interni ( ANDROID ) sia da numero voip 0310352018 o da WRTC cosa può essere?
Port Mapping
5000-5001 tcp
5060 tcp e udp
5061 tcp
5090 tcp e udp
9000-9999 udp e tcp
4516 tcp
3478 tcp e udp
5200-5299 tcp
allego anche log del server...sono disperato!!!
11-feb-2015 10:30:56.143 Leg L:3.1[Line:90000<<WebRTC] is terminated: Cause: BYE from PBX
11-feb-2015 10:30:56.143 [CM503008]: Call(C:3): Call is terminated
11-feb-2015 10:30:56.141 Leg L:3.2[Extn:10] is terminated: Cause: BYE from 192.168.1.100:49146
11-feb-2015 10:30:35.686 Currently active calls - 1: [3]
11-feb-2015 10:30:25.725 [CM503007]: Call(C:3): Extn:10 has joined, contact <sip:[email protected]:49146>
11-feb-2015 10:30:25.724 [CM503007]: Call(C:3): Line:90000<<WebRTC has joined, contact <sip:[email protected]:5062>
11-feb-2015 10:30:25.722 L:3.2[Extn:10] has joined to L:3.1[Line:90000<<WebRTC]
11-feb-2015 10:30:23.522 [CM503025]: Call(C:3): Calling T:Extn:10@[Dev:sip:[email protected]:49146;ob;inst="012cf822"] for L:3.1[Line:90000<<WebRTC]
11-feb-2015 10:30:23.477 [CM503027]: Call(C:3): From: Line:90000<<WebRTC ("WebRTC (192.168.1.254)" <sip:[email protected]:5060>) to T:Extn:10@[Dev:sip:[email protected]:49146;ob;inst="012cf822"]
11-feb-2015 10:30:23.477 [CM503004]: Call(C:3): Route 1: from L:3.1[Line:90000<<WebRTC] to T:Extn:10@[Dev:sip:[email protected]:49146;ob;inst="012cf822"]
11-feb-2015 10:30:23.477 [CM505002]: Gateway:[webrtc] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX WebRTC proxy] PBX contact: [sip:[email protected]:5060]
11-feb-2015 10:30:23.476 [CM503001]: Call(C:3): Incoming call from Line:90000<<WebRTC to <sip:[email protected]:5060>
11-feb-2015 10:30:23.474 Line limit check: Current # of calls for line Lc:90000(@webrtc[<sip:[email protected]:5062>]) is 1; limit is 25
11-feb-2015 10:30:23.464 [CM503012]: Inbound any hours rule (unnamed) for 90000 forwards to DN:10
11-feb-2015 10:30:16.109 [CM504001]: Endpoint Extn:10: new contact is registered. Contact(s): [sip:[email protected]:49146 / 10]
11-feb-2015 10:29:32.795 [CM504002]: Endpoint Extn:10: a contact is unregistered. Contact(s): []
11-feb-2015 10:29:21.115 Leg L:2.2[Extn:10] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.10:5075
11-feb-2015 10:29:21.115 [CM503003]: Call(C:2): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.10:5075
11-feb-2015 10:29:21.015 [CM503008]: Call(C:2): Call is terminated
11-feb-2015 10:29:21.014 Leg L:2.1[Line:90000<<WebRTC] is terminated: Cause: CANCEL from 127.0.0.1:5062
11-feb-2015 10:29:14.966 [CM503025]: Call(C:2): Calling T:Extn:10@[Dev:sip:[email protected]:5075;ob] for L:2.1[Line:90000<<WebRTC]
11-feb-2015 10:29:14.923 [CM503027]: Call(C:2): From: Line:90000<<WebRTC ("WebRTC (192.168.1.254)" <sip:[email protected]:5060>) to T:Extn:10@[Dev:sip:[email protected]:5075;ob]
11-feb-2015 10:29:14.923 [CM503004]: Call(C:2): Route 1: from L:2.1[Line:90000<<WebRTC] to T:Extn:10@[Dev:sip:[email protected]:5075;ob]
11-feb-2015 10:29:14.923 [CM505002]: Gateway:[webrtc] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX WebRTC proxy] PBX contact: [sip:[email protected]:5060]
11-feb-2015 10:29:14.922 [CM503001]: Call(C:2): Incoming call from Line:90000<<WebRTC to <sip:[email protected]:5060>
11-feb-2015 10:29:14.920 Line limit check: Current # of calls for line Lc:90000(@webrtc[<sip:[email protected]:5062>]) is 1; limit is 25
11-feb-2015 10:29:14.909 [CM503012]: Inbound any hours rule (unnamed) for 90000 forwards to DN:10
11-feb-2015 10:28:54.593 [CM504001]: Endpoint Extn:10: new contact is registered. Contact(s): [sip:[email protected]:5075 / 10]
11-feb-2015 10:20:46.812 [CM504002]: Endpoint Extn:10: a contact is unregistered. Contact(s): []
11-feb-2015 10:20:05.807 Leg L:1.2[Extn:10] is terminated: Cause: BYE from PBX
11-feb-2015 10:20:05.806 [CM503008]: Call(C:1): Call is terminated
Port Mapping
5000-5001 tcp
5060 tcp e udp
5061 tcp
5090 tcp e udp
9000-9999 udp e tcp
4516 tcp
3478 tcp e udp
5200-5299 tcp
