Ho lo stesso problema, ma facendo la procedura non rinnova il certificato:
2020/05/22 18:23:52.908|Dbg|0001| Connecting to PhoneSystem
2020/05/22 18:23:54.272|Dbg|0001| PhoneSystemConnected = True (waittime=00:00:01.3640995)
2020/05/22 18:23:54.272|Dbg|0001| PhoneSystemConnected(2) = True
2020/05/22 18:23:54.275|Dbg|0001| Parameter name: REGENERATE_CERTIFICATE_EXPIRED_IN_DAYS, value = 25
2020/05/22 18:23:54.275|Dbg|0001| Is temporary certificate generated = False
2020/05/22 18:23:54.275|Dbg|0001| regenerateFromStr = , regenerateToStr =
2020/05/22 18:23:54.275|Dbg|0001| SIPPORT port in PBX = 5060
2020/05/22 18:23:54.275|Dbg|0001| Using SipPort = 5060
2020/05/22 18:23:54.275|Dbg|0001| TNL_CLIENT_LISTEN_PORT port in PBX = 5090
2020/05/22 18:23:54.275|Dbg|0001| Using TunnelPort = 5090
2020/05/22 18:23:54.316|Dbg|0001| Processing directory = C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1, regenerateCertificateExiredInDays = 25, temporaryCertificateGenerated = False, regenerateNotSelfSignedCertificatesFrom = 0, regenerateNotSelfSignedCertificatesTo = 7, isPassiveFailoverMode = False
2020/05/22 18:23:54.316|Dbg|0001| Real (not self-signed) certificates regenerates from 0 to 7 hour. Skip.
2020/05/22 18:23:54.316|Dbg|0001| Processing directory C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1 completed
2020/05/22 18:23:54.316|Dbg|0001| Disconnecting from PhoneSystem
2020/05/22 18:23:56.697|Dbg|0001| Phone System disconnected
2020/05/22 18:23:56.697|Dbg|0001| Finish updating certificates. Updated 0 certificates
mail ricevuta:
HTTPS Certificate renewal Failed - Error:
System.UnauthorizedAccessException: Access to the path 'C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1\dhparam.pem' is denied.
at System.IO.FileStream.ValidateFileHandle(SafeFileHandle fileHandle)
at System.IO.FileStream.CreateFileOpenHandle(FileMode mode, FileShare share, FileOptions options)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.IO.File.InternalWriteAllBytes(String path, Byte[] bytes)
at System.IO.File.WriteAllBytes(String path, Byte[] bytes)
at PostInstall.CertificateHelper.SaveFile(String fullPath, Byte[] content, String comment)
at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Boolean isPassiveFailoverMode)
at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
