Nel log ora mi compare con una certa frequenza quanto indicato di seguito, da che dipende?
Codice:
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP10: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP10]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP9: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP9]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP8: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP8]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP6: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP6]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP7: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP7]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:*0: new contact is registered. Contact(s): [sip:*[email protected]:5483 / *0]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP3: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP3]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:*1: new contact is registered. Contact(s): [sip:*[email protected]:5483 / *1]
24/10/2020 21:53:56 - [CM504001]: Endpoint Extn:14: new contact is registered. Contact(s): [sip:[email protected]:5483 / 14]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:*777: new contact is registered. Contact(s): [sip:*[email protected]:5483 / *777]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:*888: new contact is registered. Contact(s): [sip:*[email protected]:5483 / *888]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP2: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP2]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP4: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP4]
24/10/2020 21:53:56 - [CM504001]: Endpoint Extn:11: new contact is registered. Contact(s): [sip:[email protected]:5483 / 11]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP1: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP1]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP5: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP5]
24/10/2020 21:53:56 - [CM504001]: Endpoint ParkOrb:SP0: new contact is registered. Contact(s): [sip:[email protected]:5483 / SP0]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:PlayFile: new contact is registered. Contact(s): [sip:[email protected]:5483 / PlayFile]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:HotDeskIVR: new contact is registered. Contact(s): [sip:[email protected]:5483 / HotDeskIVR]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:DialCode: new contact is registered. Contact(s): [sip:[email protected]:5483 / DialCode]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:QCB: new contact is registered. Contact(s): [sip:[email protected]:5483 / QCB]
24/10/2020 21:53:56 - [CM504008]: Fax Service: Fax.88 registered as sip:[email protected]:5060 with contact sip:[email protected]:5483;rinstance=445428d5811570dc
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:80: new contact is registered. Contact(s): [sip:[email protected]:5483 / 80]
24/10/2020 21:53:56 - [CM504001]: Endpoint VMail:99: new contact is registered. Contact(s): [sip:[email protected]:5483 / 99]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:HOL: new contact is registered. Contact(s): [sip:[email protected]:5483 / HOL]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:77: new contact is registered. Contact(s): [sip:[email protected]:5483 / 77]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:IVRForward: new contact is registered. Contact(s): [sip:[email protected]:5483 / IVRForward]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:MakeCall: new contact is registered. Contact(s): [sip:[email protected]:5483 / MakeCall]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:EndCall: new contact is registered. Contact(s): [sip:[email protected]:5483 / EndCall]
24/10/2020 21:53:56 - [CM504001]: Endpoint Ivr:RecordFile: new contact is registered. Contact(s): [sip:[email protected]:5483 / RecordFile]
24/10/2020 21:53:56 - [CM504001]: Endpoint Conf:70: new contact is registered. Contact(s): [sip:[email protected]:5483 / 70]
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:*0: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint Extn:11: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint Ivr:MakeCall: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:SP8: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint VMail:99: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:SP3: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:SP7: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint Ivr:HotDeskIVR: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:SP9: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint ParkOrb:*1: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint Ivr:DialCode: a contact is unregistered. Contact(s): []
24/10/2020 21:53:56 - [CM504002]: Endpoint Ivr:IVRForward: a contact is unregistered. Contact(s): []
