Buongiorno, ho installato un patton 4120. Tutto funziona benissimo ad eccezione delle chiamate in ingresso,che arrivano, ma che mi arrivano tutte anonime.
Di seguito la configurazione del Patton, che tra l'altro è quella di default del 3cx
# SN4120/2BIS4V #
# R6.3 2013-05-01 H323 SIP #
# 2015-07-09T15:52:07 #
# SN/00A0BA0B357E #
# Generated configuration file #
cli version 3.20
clock local default-offset +01:00
webserver port 80 language en
sntp-client
sntp-client server primary 192.168.1.2 port 123 version 4
sntp-client local-clock-offset
system
ic voice 0
low-bitrate-codec g729
system
clock-source 1 bri 0 0
clock-source 2 bri 0 1
profile ppp default
profile call-progress-tone defaultDialtone
play 1 200 425 0
pause 2 200
play 3 600 425 0
pause 4 1000
profile call-progress-tone defaultBusytone
play 1 200 425 -7
pause 2 200
profile tone-set default
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
codec 3 g729 rx-length 20 tx-length 20
fax transmission 1 relay t38-udp
modem transmission 1 bypass g711alaw64k rx-length 20 tx-length 20
profile pstn default
profile sip default
no autonomous-transitioning
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
ipaddress 192.168.1.130 255.255.255.0
tcp adjust-mss rx mtu
tcp adjust-mss tx mtu
context cs switch
routing-table called-e164 RT_ISDN_TO_SIP_0
route T2 dest-interface IF_SIP_0 MAPPING_INCOMING_CALLS
routing-table called-e164 RT_ISDN_TO_SIP_1
route T2 dest-interface IF_SIP_1 MAPPING_INCOMING_CALLS
routing-table called-e164 RT_SIP_TO_ISDN_0
route default dest-interface IF_ISDN_0 OUTBOUND
routing-table called-e164 RT_SIP_TO_ISDN_1
route default dest-interface IF_ISDN_1 OUTBOUND
mapping-table calling-pi to calling-e164 MAP_REMOVE_BLANK_CALLERID
map restricted to ""
mapping-table calling-e164 to calling-e164 MAP_LEADING_ZERO
map (3.%)-(.%)-(.%)-(.%)-(.%) to \1\2\3\4\5
map (3.%)-(.%)-(.%)-(.%) to \1\2\3\4
map (3.%)-(.%)-(.%) to \1\2\3
map (3.%)-(.%) to \1\2
map (3.%) to \1
map (.%)-(.%)-(.%)-(.%)-(.%) to 0\1\2\3\4\5
map (.%)-(.%)-(.%)-(.%) to 0\1\2\3\4
map (.%)-(.%)-(.%) to 0\1\2\3
map (.%)-(.%) to 0\1\2
map (.%) to 0\1
mapping-table calling-e164 to calling-name MAP_CID_TO_CNAME
map (.%) to \1
mapping-table calling-e164 to calling-e164 SET_CNPN
map 0(.%) to \1
mapping-table calling-type-of-number to calling-type-of-number TYPE
map default to national
mapping-table calling-numbering-plan to calling-numbering-plan PLAN
map default to isdn-telephony
complex-function MAPPING_INCOMING_CALLS
execute 1 MAP_REMOVE_BLANK_CALLERID
execute 2 MAP_LEADING_ZERO
execute 3 MAP_CID_TO_CNAME
complex-function OUTBOUND
execute 1 PLAN
execute 2 SET_CNPN
execute 3 TYPE
interface isdn IF_ISDN_0
route call dest-table RT_ISDN_TO_SIP_0
call-reroute emit
call-hold disable
diversion emit
caller-name
user-side-ringback-tone
interface isdn IF_ISDN_1
route call dest-table RT_ISDN_TO_SIP_1
call-reroute emit
call-hold disable
diversion emit
caller-name
interface sip IF_SIP_0
bind context sip-gateway GW_SIP_0
route call dest-table RT_SIP_TO_ISDN_0
remote 192.168.1.77 5060
early-connect
early-disconnect
call-reroute accept
address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
trust remote
interface sip IF_SIP_1
bind context sip-gateway GW_SIP_1
route call dest-table RT_SIP_TO_ISDN_1
early-connect
early-disconnect
call-reroute accept
address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
trust remote
context cs switch
no shutdown
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10001 password dZ8edXkjFnM= encrypted
username 10002 password iAaKwKfxX4Q= encrypted
location-service LS_10001
domain 1 192.168.1.77
identity-group default
authentication outbound
authenticate 1 authentication-service AS_ALL_LINES username 10001
identity 10001
registration outbound
registrar 192.168.1.77 5060
lifetime 300
register auto
location-service LS_10002
authenticate 1 authentication-service AS_ALL_LINES username 10002
identity 10002
lifetime 300
register auto
interface LAN
bind interface IF_IP_LAN context router port 5060
bind location-service LS_10001
no shutdown
interface LAN
bind interface IF_IP_LAN context router port 5062
bind location-service LS_10002
no shutdown
port ethernet 0 0
medium 10 half
encapsulation ip
bind interface IF_IP_LAN router
no shutdown
port bri 0 0
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bchan-number-order ascending
encapsulation cc-isdn
bind interface IF_ISDN_0 switch
port bri 0 0
no shutdown
port bri 0 1
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
bind interface IF_ISDN_1 switch
port bri 0 1
no shutdown
# SN4120/2BIS4V #
# SN/00A0BA0B357E #
cli version 3.20
sntp-client
system
ic voice 0
system
profile ppp default
play 1 200 425 0
pause 2 200
play 3 600 425 0
pause 4 1000
play 1 200 425 -7
pause 2 200
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface IF_IP_LAN
context cs switch
map (3.%) to \1
map (.%) to 0\1
map (.%) to \1
map 0(.%) to \1
execute 1 PLAN
execute 2 SET_CNPN
execute 3 TYPE
call-reroute emit
call-hold disable
diversion emit
caller-name
call-reroute emit
call-hold disable
diversion emit
caller-name
early-connect
early-disconnect
call-reroute accept
trust remote
early-connect
early-disconnect
call-reroute accept
trust remote
context cs switch
no shutdown
identity 10001
lifetime 300
register auto
identity 10002
lifetime 300
register auto
interface LAN
no shutdown
interface LAN
no shutdown
port ethernet 0 0
medium 10 half
encapsulation ip
no shutdown
port bri 0 0
clock auto
encapsulation q921
q921
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
port bri 0 0
no shutdown
port bri 0 1
clock auto
encapsulation q921
q921
protocol pp
uni-side auto
encapsulation q931
q931
protocol dss1
uni-side user
port bri 0 1
no shutdown
