patton config
Ho un problema con un patton 4634
ho due ISDN in ricerca automatica in entrata configurate in punto-punto
in entrata ricevo fino a 4 chiamate, tutto ok
in uscita non riesco a fare più di due chiamate. Qualche idea su dove intervenire
questo lo status del patton:
Domain: 192.168.0.2
Local Address: 192.168.0.7:5060
Remote Address: (none):0
Default Server: 192.168.0.2:0;lr
Early Proceeding: yes
Hold using zero IP: yes
Early Connect: no
Early Disconnect: no
Call-Transfer: accept & emit
Call-Reroute: disabled
AOC-D Information: accept
Pull-In Externally Looped Calls: yes
Address-Complete Indication: Accept: clear
PhoneContext
Use Calling Remote-Party-ID: no
Use Called Remote-Party-ID: yes
Use Privacy: no
Outgoing Call Parameter Source
From Header
User: from call URI or E.164 ()
Host-Port: from call URI or E.164 (:0)
To Header
Host-Port: from interface (:0)
Request URI
User: fix (10001)
Host-Port: from To header (:0)
Target Parameter: none (Target: , Cause: )
Calling Remote-Party-ID Header
Header User: from call URI or E.164 ()
Header Host-Port: from call URI or E.164 (:0)
Called Remote-Party-ID Header
Header Host-Port: from interface (:0)
Identity Header
Diversion Header
Header Host-Port: none (:0)
Incoming Call Parameter Source
Calling Party
E.164: from Identity header ()
URI: from Identity header ((invalid))
Name: from Identity header ()
Redirecting E.164: none (Target: , Cause: Unknown)
Called Party
E.164: from Request-URL ()
URI: from Remote-Party-ID header ((invalid))
Name: from Remote-Party-ID header ()
Play Tones: yes
VoIP Profile: default
Used: by 2 module(s)
Voice Codecs
G.711 A-law: Rx=20ms Tx=20ms
G.711 u-law: Rx=20ms Tx=20ms
Fax Codecs
T.38 UDP: Rx=1ms Tx=1ms Relay
Modem Codecs
Codec Negotiation: enabled
Dejitter
Mode: Adaptive
Max. Delay: 60ms
Max. Packet Loss: 4/1000
Shrink Speed: 1
Grow Step: 1
Grow Attenuation: 1
High Pass Filter: enabled
Post Filter: enabled
Fax
Detection: CED Tone
T.38 High Speed Redundant Packets: 0
T.38 Low Speed Redundant Packets: 0
Max. Bit Rate: 14400bps
Volume: -9.500dB
Error Correction: enabled
HDLC: enabled
Dejitter Max Delay: 200ms
Modem
Volume: -9.500dB
HDLC: enabled
DTMF
Relay: enabled
Mute Encoder: enabled
RTP
Payload Type NTE: 101
Payload Type NSE: 100
Payload Type Clearmode: 97
Payload Type Redundancy: 255
Payload Type G.726-32: 2
Payload Type G.726-32-AAL2: 2
BCD
Avtivation: on-rx-activation
Timeout: 1000
Traffic Class: local-voice
SIP Profile: default
Autonomous Transitioning: disabled
Tone-Set Profile: (none)
Routing Destination: router (IF_SIP_0-precall-service)
State: Up
Allow New Calls: yes
Allow Incoming Calls: yes
Wait For Name: no
Wait For Number: no
Proceeding Timeout: 4000
Early Alerting Timeout: 0
Endpoints
Endpoint: IF_SIP_0-00b69fd8
Domain: 192.168.0.2
Local Host: 192.168.0.7
Local Port: 5060
Remote Host: (none)
Remote Port: (default)
Default Server: 192.168.0.2/0 (loose-router)
Session-Timer Interval: 0s
Session-Timer Version: 8
Call-Transfer Version: 5
Early Connect: no
Phone Context
Play Tones: yes
Call Routing Destination: router (IF_SIP_0-precall-service)
Active State: Disconnected
Passive State: Idle
Endpoint: IF_SIP_0-009297b8
Domain: 192.168.0.2
Local Port: 5060
Remote Host: (none)
Early Connect: no
Phone Context
Play Tones: yes
Active State: Connected
Passive State: Idle
