Patton riceve ma non chiama
jimmyc
Ciao a tutti, ho un installazione 3CX 14 con un Patton 4120 2 BRI
In entrata nessun problema le chiamate arrivano correttamente in uscita invece non vanno.
Log del Patton:
02:23:50 ICC > [EP IF_ISDN_0-00c9f918] State: CALL INITIATED, Event: TERMINAL
RELEASE IND
02:23:50 CC > [EP IF_ISDN_0-00c9f918/active] Set call-leg property: Cause ->
Temporary failure
02:23:50 ICC > [EP IF_ISDN_0-00c9f918] Set state to NULL
02:23:50 CC > [EP IF_ISDN_0-00c9f918/active] Drop call 00ad99a8
02:23:50 CC > [EP IF_ISDN_0-00c9f918/active] Set call-leg property: State ->
RELEASED
02:23:50 ICC > [IF_ISDN_0] CLEARING CALL IF_ISDN_0-00c9f918
02:23:50 ICC > [IF_ISDN_0] Removed endpoint IF_ISDN_0-00c9f918
02:23:50 CC > [EP router-00c9b9f0/incoming] Set call-leg property: Cause ->
Temporary failure
02:23:50 CC > [EP router-00c9b9f0/incoming] Set call-leg property: State ->
RELEASED
02:23:50 CC > [EP router-00c9b9f0/outgoing] Drop call 00ad99a8
02:23:50 CC > [EP router-00c9b9f0/outgoing] Set call-leg property: Cause ->
Normal call clearing
02:23:50 CC > [EP router-00c9b9f0/outgoing] Set call-leg property: State ->
RELEASED
02:23:50 ICC > [IF_ISDN_0] Destroying finished calls.
02:23:50 ICC > [IF_ISDN_0] Destroyed endpoint IF_ISDN_0-00c9f918
02:23:50 CC > [EP IF_SIP_0-00ee9c78/active] Set call-leg property: State ->
RELEASED
02:23:50 SIP_TR> [STACK] > 454 Stack: to 192.168.1.150
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 192.168.1.150:5060;branch=z9hG4bK-d8754z-5f32c6692d14ec02-1---d
8754z-;rport=5060;received=192.168.1.150
From: "Simona"<sip:[email protected]:5060>;tag=e24fd32b
To: <sip:[email protected]:5060>;tag=2849266398
Call-ID: NDliNjkyYjdjNjcyYmY0ZTlkMDIwZTI3OGFjNzRiMGE.
CSeq: 1 INVITE
Server: Patton SN4120 2BIS4V 00A0BA0B43A9 R6.3 2013-05-01 H323 SIP M5T SIP Stack
/4.1.12.18
Content-Length: 0
02:23:50 CC > [EP IF_SIP_0-00ee9c78/active] Drop call 00ad9318
02:23:50 CC > [EP IF_SIP_0-00ee9c78/active] Set call-leg property: Cause ->
02:23:50 SIP_TR> [STACK] < 363 Stack: from 192.168.1.150
ACK sip:[email protected]:5060 SIP/2.0
8754z-;rport
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
02:23:50 SIP_TR> [STACK] < 926 Stack: from 192.168.1.150
INVITE sip:[email protected]:5062 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.150:5060;branch=z9hG4bK-d8754z-d10c485b5c58097b-1---d
8754z-;rport
Max-Forwards: 70
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]:5062>
From: "Simona"<sip:[email protected]:5060>;tag=b5130f5e
Call-ID: N2M4Njc1NGMwNDBmNDI5Mjg2NTQ2OWJmOGRkMTZlZDI.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, IN
FO, MESSAGE
Content-Type: application/sdp
Supported: replaces
User-Agent: 3CXPhoneSystem 14.0.44241.523 (44097)
Content-Length: 333
v=0
o=3cxPS 460366807040 213607514113 IN IP4 192.168.1.150
s=3cxPS Audio call
c=IN IP4 192.168.1.36
t=0 0
m=audio 11794 RTP/AVP 0 8 9 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Network -
> GW_SIP_1/192.168.1.151
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: E164-Numb
er -> 90002
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: URI -> si
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Type-Of-N
umber -> Unknown
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Numbering
-Plan -> Unknown
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Presentat
ion-Indicator -> Presentation allowed
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Name -> S
imona
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Screening
-Indicator -> User provided, not screened
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Supports
Overlap-Sending -> true
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Supported
Codecs -> Voice: G.711 u-law[20/20], G.711 A-law[20/20], G.729A[20/20]
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Codec Neg
otiating -> Idle
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Unique Id
entifier -> N2M4Njc1NGMwNDBmNDI5Mjg2NTQ2OWJmOGRkMTZlZDI.
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: IP-Addres
s -> 192.168.1.150
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Call-Leg-
ID -> 0x00c9f450
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: State ->
CONNECTED
02:23:51 CC > [Call 00ac71b8] Set call property: Context -> 0x00000009
02:23:51 CC > [Call 00ac71b8] Set call property: Information-Transfer-Capabi
lity -> 3.1kHz Audio
02:23:51 CC > [Call 00ac71b8] Set call property: Hops -> 0x00000010
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Dial to provider router (IF_SIP_
1-precall-service) using call 00ac71b8
02:23:51 CC > [EP router-00ca24b0/incoming] Accept call 00ac71b8
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: E164-Numb
er -> 0354258202
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Type-Of-N
umber -> Unknown
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Numbering
-Plan -> Unknown
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Name ->
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Alert-Inf
o ->
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: URI -> si
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Network -
> router
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Call-Leg-
ID -> 0x00ee8e48
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: State ->
TRYING
02:23:51 CC > [EP router-00ca24b0] Start route-lookup
02:23:51 CC > [EP router-00ca24b0] Route found; immediately place call
02:23:51 CC > [EP router-00ca24b0] Route to provider 'IF_ISDN_1'
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: E164-Numb
er -> 90002
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: URI -> si
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Type-Of-N
umber -> National number
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Numbering
-Plan -> ISDN/Telephony numbering plan
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Presentat
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Name -> S
imona
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Screening
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Supports
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Supported
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Codec Neg
otiating -> Idle
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Unique Id
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: IP-Addres
s -> 192.168.1.150
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Network -
> router
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Call-Leg-
ID -> 0x00ad1010
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: State ->
CONNECTED
02:23:51 CC > [Call 00ad0f18] Set call property: Context -> 0x00000009
02:23:51 CC > [Call 00ad0f18] Set call property: Information-Transfer-Capabi
02:23:51 CC > [Call 00ad0f18] Set call property: Hops -> 0x0000000f
02:23:51 CC > [EP router-00ca24b0/outgoing] Dial to provider IF_ISDN_1 () us
ing call 00ad0f18
02:23:51 ICC > [IF_ISDN_1] Added endpoint IF_ISDN_1-00ca02c0
02:23:51 ICC > [IF_ISDN_1] NEW CALL. Allocated Endpoint IF_ISDN_1-00ca02c0
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Accept call 00ad0f18
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: E164-Num
ber -> 0354258202
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Type-Of-
Number -> Unknown
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Numberin
g-Plan -> Unknown
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Name ->
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Alert-In
fo ->
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: URI -> s
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Quality-
Of-Service -> MOS 4.50, DS0
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Network
-> IF_ISDN_1
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Call-Leg
-ID -> 0x00ca4a00
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: State ->
TRYING
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] do not reroute because: no endpoint wi
th call key: N2M4Njc1NGMwNDBmNDI5Mjg2NTQ2OWJmOGRkMTZlZDI.
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] AOC-S User << Call Setup
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] AOC-D User << Call Setup
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] AOC-E User << Call Setup
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] >> [080005]
SETUP (DSS1 User)
[04039090A3]
Bearer capability : 3.1kHz Audio - CCITT
circuit mode - 64kBit/s - G.711 A-law
[1E028583]
Progress indicator : origination address is non-ISDN
private network serving remote user - CCITT
[6C0721803930303032]
Calling party number : 90002
national number - E.164 numbering plan
presentation allowed - user provided not screened
[700B8030333534323538323032]
Called party number : 0354258202
unknown number - unknown numbering plan
[7E070453696D6F6E61]
User to user info : IA5 characters
"Simona"
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] Set state to CALL INITIATED
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Endpoint
-Is-Isdn -> true
02:23:51 CC > [Call 00ac71b8] Set call property: Hops -> 0x0000000f
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Endpoint-
Is-Isdn -> true
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Quality-O
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] State: CALL INITIATED, Event: PEER CON
NECTED
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] Hold State: IDLE, Hold Event: PEER CON
NECTED
02:23:51 ICC > [IF_ISDN_1] << Message: primitive=46
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] << [08004D]
RELEASE (DSS1 User)
[080280A9]
Cause : temporary failure
user - CCITT - Q.931
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] State: CALL INITIATED, Event: TERMINAL
RELEASE IND
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Set call-leg property: Cause ->
Temporary failure
02:23:51 ICC > [EP IF_ISDN_1-00ca02c0] Set state to NULL
02:23:51 CC > [EP IF_ISDN_1-00ca02c0/active] Drop call 00ad0f18
RELEASED
02:23:51 ICC > [IF_ISDN_1] CLEARING CALL IF_ISDN_1-00ca02c0
02:23:51 ICC > [IF_ISDN_1] Removed endpoint IF_ISDN_1-00ca02c0
02:23:51 CC > [EP router-00ca24b0/incoming] Set call-leg property: Cause ->
Temporary failure
RELEASED
02:23:51 CC > [EP router-00ca24b0/outgoing] Drop call 00ad0f18
02:23:51 CC > [EP router-00ca24b0/outgoing] Set call-leg property: Cause ->
RELEASED
02:23:51 ICC > [IF_ISDN_1] Destroying finished calls.
02:23:51 ICC > [IF_ISDN_1] Destroyed endpoint IF_ISDN_1-00ca02c0
RELEASED
02:23:51 SIP_TR> [STACK] > 454 Stack: to 192.168.1.150
To: <sip:[email protected]:5062>;tag=1601106218
CSeq: 1 INVITE
/4.1.12.18
Content-Length: 0
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Drop call 00ac71b8
02:23:51 SIP_TR> [STACK] < 363 Stack: from 192.168.1.150
ACK sip:[email protected]:5062 SIP/2.0
8754z-;rport
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
02:23:51 CC > [EP IF_SIP_1-00ee9c78/active] Set call-leg property: Cause ->
