Prima configurazione 3cx
Buongiorno tutti,
Sono alla prima configurazione di 3cx , vorrei utilizzare il centralino solo con dei 3cxphone (il software) e con un SIP (12voip.com o pure Skype).
Non so come mai non funziona , mi dice sul 3cxphone ( "destinazione non trovata")
E sul centralino (vedi log sotto)
Mi potete dare delle dritte ?
Grazie .
15:27:18.744 [CM503020]: Normal call termination. Reason: Not found
15:27:18.744 [CM503016]: Call(1): Attempt to reach failed. Reason: Not Found
15:27:18.744 [CM503014]: Call(1): No known route to target:
15:27:18.728 [CM503010]: Making route(s) to
15:27:18.728 [CM505001]: Ext.300: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:[email protected]:5060]
15:27:18.728 [CM503001]: Call(1): Incoming call from Ext.300 to
15:27:06.682 [CM504001]: Ext.300: new contact is registered. Contact(s): [sip:[email protected]:1174;rinstance=4a4cc050a9f448d3/300]
15:27:03.124 [CM504002]: Ext.300: a contact is unregistered. Contact(s): []
15:26:45.055 [CM504001]: Ext.300: new contact is registered. Contact(s): [sip:[email protected]:1173;rinstance=90e539cf2725f7b8/300]
15:26:12.086 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=3daab18b6f62b6af/*1]
15:26:12.086 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=05225e3fdf8829cd/*0]
15:26:12.071 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*[email protected]:40000;rinstance=3a128dd192c1153b/*777]
15:26:11.680 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=f16e1f60d938b634/IVRForward]
15:26:11.680 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=5ecf0e7244a05236/EndCall]
15:26:11.570 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=9b83e141332a8edc/999]
15:26:11.258 [CM504003]: Sent registration request for 10000@skype
15:26:11.100 IP(s) added:[192.168.1.249]
15:26:07.194 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
15:26:06.408 [EC200006]: Conference server is connected: application:Vsrv01:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:57833
15:26:06.172 [EC200004]: IVR server is connected: application:Vsrv01:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:57828
15:26:05.656 [EC200005]: Parking Orbit server is connected: application:Vsrv01:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:57827
15:26:05.282 [EC200002]: Media server is connected: application:Vsrv01:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:57826
15:26:04.126 [EC100007]: External application is connected: application:Vsrv01:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:57823
15:26:02.596 [CM504003]: Sent registration request for 10000@skype
15:26:02.471 [CM506002]: Resolved SIP external IP:port (94.81.XX.XXX:5060) on Transport 192.168.1.249:5060
15:26:02.299 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 77.72.169.166:3478 over Transport 192.168.1.249:5060
15:26:01.097 Failed to obtain short path name for [C:ProgramData3CXBinCert]
15:26:01.097 [CM501006]: Default Local IP address: [192.168.1.249]
15:26:01.097 [CM501007]: *** Started Calls Controller thread ***
15:26:01.097 [CM501002]: Version: 9.0.15776.0
15:26:01.097 [CM501001]: Start 3CX PhoneSystem Call Manager
15:26:00.832 [EC200001]: Configuration server is connected: application:Vsrv01:5485/DBProvider local:127.0.0.1:57820 remote:127.0.0.1:5485
intanto toglierei dal post i riferimenti al tuo indirizzo ip pubblico.....
Grazie :D
se imposto direttamente il sip al 3cxphone funziona corretamente ,riesco telefonare, ma tramite il centralino non funziona. . .
avete qualche idea?
devi inserire le regole di uscita, fai un cerca e trovi post a sufficenza...
per skype ad esempio a,b,c,d,e, etc
