Questo il log di una chiamata andata persa...
03/12/2020 16:43:04 - Currently active calls [none]
03/12/2020 16:42:56 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:42:55 - CSTA: on info success: CSTA Recv 200/INFO from 192.168.1.163:5060 tid=1480952ddf7f5402 Call-ID=EO0UxU4Vb1Y2QtGizkAZJw..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.175:5065;branch=z9hG4bK-524287-1---1480952ddf7f5402;rport=5065
Contact: <sip:
[email protected]:5060>
To: <sip:
[email protected]:5060>;tag=4897345609
[email protected]:5065>;tag=dfbb0263
Call-ID: EO0UxU4Vb1Y2QtGizkAZJw..
CSeq: 1378 INFO
Content-Type: application/csta+xml
User-Agent: Fanvil X1S 2.2.11 0c383e415b56
Mac: 0c383e415b56
Content-Length: 265
<?xml version="1.0" encoding="UTF-8"?>
<SnapshotDeviceResponse xmlns="
http://www.ecmainternational.org/standards/ecma-323/csta/ed5">
<crossRefIDorSnapshotData>
<snapshotData></snapshotData>
</crossRefIDorSnapshotData>
</SnapshotDeviceResponse>
03/12/2020 16:42:55 - CSTA: onReadyToSend: CSTA Send Req INFO from 0.0.0.0:0 tid=a679d0176c7cee39 Call-ID=EO0UxU4Vb1Y2QtGizkAZJw..:
INFO sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---a679d0176c7cee39;rport
Max-Forwards: 70
Contact: <sip:006>
To: <sip:
CSeq: 1378 INFO
Content-Length: 208
<SnapshotDevice xmlns="
http://www.ecma-international.org/standards/ecma-323/csta/ed5">
<snapshotObject>sip:
[email protected]:5065</snapshotObject>
</SnapshotDevice>
03/12/2020 16:42:49 - Leg L:369.1[Line:10002<<04319xxxx] is terminated: Cause: BYE from PBX
03/12/2020 16:42:49 - Terminated from <sip:
[email protected]:5060>;tag=be9e00e5bd to <sip:
[email protected]:5065>;tag=afb3c907; reason: Rejected
03/12/2020 16:42:49 - L:369.1[Line:10002<<04319xxxx] Sending: OnSendResp Send 480/INVITE from 0.0.0.0:0 tid=19601125f656579ec Call-ID=6c516c727ab31ef1:
SIP/2.0 480 Temporarily Unavailable
Via: SIP/2.0/UDP 192.168.1.173:5060;branch=z9hG4bK19601125f656579ec
To: <sip:
Call-ID: 6c516c727ab31ef1
CSeq: 9268 INVITE
Warning: 499 3cx "No answer"
Content-Length: 0
03/12/2020 16:42:49 - SendMsg from <sip:
[email protected]:5065>;tag=afb3c907 to <sip:
03/12/2020 16:42:49 - Leg L:369.5[VMail:999] is terminated: Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:49 - L:369.5[VMail:999] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=6af86e5d4fb47669 Call-ID=Bz7mkJz2IY1GlzW2_qFt-w..:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/UDP 127.0.0.1:5065;branch=z9hG4bK-524287-1---6af86e5d4fb47669;rport
To: <sip:000@v****.my3cx.it:5065>;tag=30fa7760
di tixxxxx mon***"<sip:
[email protected]:5065;nf=e>;tag=50730163
Call-ID: Bz7mkJz2IY1GlzW2_qFt-w..
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:49 - Terminated from <sip:000@v****.my3cx.it:5065>;tag=30fa7760 to "c***r DI TESTA
[email protected]:5065;nf=e>;tag=50730163; reason: Error
03/12/2020 16:42:49 - ~Target=Ext:Ext.999
03/12/2020 16:42:49 - Call(C:369) is terminated
03/12/2020 16:42:49 - [CM503020]: Call(C:369): Normal call termination. Call originator: Line:10002<<04319xxxx. Reason: No answer
03/12/2020 16:42:49 - [CM503016]: Call(C:369): Attempt to reach <sip:
[email protected]:5065> from Line:10002<<04319xxxx has failed. Reason: No Answer
03/12/2020 16:42:49 - [Flow] Endpoint VMail:999 has no forwarding rule on reason 'No Answer'
03/12/2020 16:42:49 - [Flow] Current call diversion path:[]
03/12/2020 16:42:49 - L:369.1[Line:10002<<04319xxxx] failed to reach VMail:999, reason No Answer
03/12/2020 16:42:49 - RerouteReq
03/12/2020 16:42:49 - Call to T:VMail:999@[Dev:sip:
[email protected]:5483;rinstance=8b4eeb4413c542f9] from L:369.1[Line:10002<<04319xxxx] failed, cause: Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:49 - L:369.5[VMail:999] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=6af86e5d4fb47669 Call-ID=Bz7mkJz2IY1GlzW2_qFt-w..:
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:49 - [CM503003]: Call(C:369): Call to <sip:000@v****.my3cx.it:5065> has failed; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:49 - Session 335479 has failed in leg L:369.5[VMail:999] ; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:49 - Failure from <sip:000@v****.my3cx.it:5065>;tag=30fa7760 to "c***r DI TESTA
03/12/2020 16:42:45 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:42:34 - Currently active calls - 1: [369]
03/12/2020 16:42:34 - CSTA: onReadyToSend: CSTA Send 200/INFO from 0.0.0.0:0 tid=195261852933023151 Call-ID=ElNEtzZRZP7YZPZ4S3lo4A..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.169:5060;branch=z9hG4bK195261852933023151;rport=5060
Contact: <sip:001>
To: <sip:
[email protected]:5065>;tag=6d6be74f
[email protected]:5060>;tag=1181231122
Call-ID: ElNEtzZRZP7YZPZ4S3lo4A..
CSeq: 1743 INFO
User-Agent: 3CXPhoneSystem 16.0.6.655 (655)
Content-Length: 0
03/12/2020 16:42:34 - CSTA: on info: CSTA Recv Req INFO from 192.168.1.169:5060 tid=195261852933023151 Call-ID=ElNEtzZRZP7YZPZ4S3lo4A..:
INFO sip:
[email protected]:5065 SIP/2.0
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1743 INFO
Content-Disposition: signal; handling=required
User-Agent: Fanvil X4 2.10.1.6836 0c383e034526
MAC: 0c383e034526
Content-Length: 204
<?xml version="1.0" encoding="utf-8"?>
<SwFunctionDevicesChanged xmlns="
<sysStatRegisterID>2</sysStatRegisterID>
</SwFunctionDevicesChanged>
03/12/2020 16:42:34 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:42:30 - Updating device Dev(1698408564):[sip:
[email protected]:5060 / 001] by message: DevUpd Recv Req REGISTER from 192.168.1.169:5060 tid=2384326530799328410
[email protected]:
REGISTER sip:192.168.1.175:5065 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.169:5060;branch=z9hG4bK2384326530799328410;rport=5060
Max-Forwards: 70
Contact: <sip:
To: v**** Ufficio <sip:
[email protected]:5065>;tag=65566601
Call-ID:
[email protected]
CSeq: 3162 REGISTER
Expires: 119
Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REFER, NOTIFY, INFO, PRACK, UPDATE, MESSAGE
Proxy-Authorization: Digest username="w2oTyDgkjz",realm="3CXPhoneSystem",nonce="414d53595fc9076641:b461e73d8e8c8d1dbb45da83f51c9c3d",uri="sip:192.168.1.175:5065",response="ae7762c084d56baef4d6596b7723c382",algorithm=MD5
Supported: path
MAC: 0c383e034526
Content-Length: 0
03/12/2020 16:42:29 - Leg L:369.4[Extn:006] is terminated: Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - L:369.4[Extn:006] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=13eb211955506e4f Call-ID=VbGmSip_UNCnf15mIMB2tA..:
Via: SIP/2.0/UDP 192.168.1.175:5065;branch=z9hG4bK-524287-1---13eb211955506e4f;rport
To: <sip:
[email protected]:5065>;tag=35abd305
[email protected]:5065;nf=e>;tag=cb42e819
Call-ID: VbGmSip_UNCnf15mIMB2tA..
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:29 - Terminated from <sip:
[email protected]:5065>;tag=35abd305 to "c***r DI TESTA
[email protected]:5065;nf=e>;tag=cb42e819; reason: Error
03/12/2020 16:42:29 - L:369.4[Extn:006] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=13eb211955506e4f Call-ID=VbGmSip_UNCnf15mIMB2tA..:
To: <sip:
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:29 - [CM503003]: Call(C:369): Call to <sip:
[email protected]:5065> has failed; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - Session 335467 has failed in leg L:369.4[Extn:006] ; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - Failure from <sip:
03/12/2020 16:42:29 - Leg L:369.3[Extn:006] is terminated: Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - L:369.3[Extn:006] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=821f5c461fe5481b Call-ID=Cpm1yw4HGM4rU2et7y83aQ..:
Via: SIP/2.0/UDP 192.168.1.175:5065;branch=z9hG4bK-524287-1---821f5c461fe5481b;rport
To: <sip:
[email protected]:5065>;tag=42a0053b
[email protected]:5065;nf=e>;tag=c8041b5a
Call-ID: Cpm1yw4HGM4rU2et7y83aQ..
CSeq: 1 INVITE
Content-Length: 0
[email protected]:5065>;tag=42a0053b to "c***r DI TESTA
[email protected]:5065;nf=e>;tag=c8041b5a; reason: Error
03/12/2020 16:42:29 - L:369.3[Extn:006] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=821f5c461fe5481b Call-ID=Cpm1yw4HGM4rU2et7y83aQ..:
To: <sip:
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:29 - Session 335465 has failed in leg L:369.3[Extn:006] ; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - Leg L:369.2[Extn:001] is terminated: Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:29 - L:369.2[Extn:001] got Terminated Recv 408/INVITE from 0.0.0.0:0 tid=95bee50361d0e960 Call-ID=_GMVM_VbU0GA5x2Dh_BP3w..:
Via: SIP/2.0/UDP 192.168.1.175:5065;branch=z9hG4bK-524287-1---95bee50361d0e960;rport
To: <sip:
[email protected]:5065>;tag=b5bfd011
[email protected]:5065;nf=e>;tag=5c0f321e
Call-ID: _GMVM_VbU0GA5x2Dh_BP3w..
CSeq: 1 INVITE
Content-Length: 0
[email protected]:5065>;tag=b5bfd011 to "c***r DI TESTA
[email protected]:5065;nf=e>;tag=5c0f321e; reason: Error
03/12/2020 16:42:29 - L:369.2[Extn:001] got Failure: Failure Recv 408/INVITE from 0.0.0.0:0 tid=95bee50361d0e960 Call-ID=_GMVM_VbU0GA5x2Dh_BP3w..:
To: <sip:
CSeq: 1 INVITE
Content-Length: 0
03/12/2020 16:42:29 - Session 335463 has failed in leg L:369.2[Extn:001] ; Cause: 408 Request Timeout/INVITE from local
03/12/2020 16:42:28 - CSTA: onReadyToSend: CSTA Send 200/INFO from 0.0.0.0:0 tid=16178274796235447482 Call-ID=EO0UxU4Vb1Y2QtGizkAZJw..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.163:5060;branch=z9hG4bK16178274796235447482;rport=5060
Contact: <sip:006>
To: <sip:
CSeq: 1798 INFO
Content-Length: 0
03/12/2020 16:42:28 - CSTA: on info: CSTA Recv Req INFO from 192.168.1.163:5060 tid=16178274796235447482 Call-ID=EO0UxU4Vb1Y2QtGizkAZJw..:
INFO sip:
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1798 INFO
Mac: 0c383e415b56
Content-Length: 208
03/12/2020 16:42:23 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:42:22 - Updating device Dev(368107311):[sip:
[email protected]:5060 / 006] by message: DevUpd Recv Req REGISTER from 192.168.1.163:5060 tid=54102512681585342339
[email protected]:
Via: SIP/2.0/UDP 192.168.1.163:5060;branch=z9hG4bK54102512681585342339;rport=5060
Max-Forwards: 70
Contact: <sip:
To: Tecnici <sip:
[email protected]:5065>;tag=326238702
Call-ID:
[email protected]
CSeq: 2284 REGISTER
Expires: 120
Proxy-Authorization: Digest username="of8oFwFalL",realm="3CXPhoneSystem",nonce="414d53595fc9075e02:210c35b5f80082a7000e2fc8a0571794",uri="sip:192.168.1.175:5065",response="94fb6b6447e3913f317066cbd99f3d21",algorithm=MD5
Supported: path
Mac: 0c383e415b56
Content-Length: 0
03/12/2020 16:42:21 - Updating device Dev(317302878):[sip:
[email protected]:5060 / 006] by message: DevUpd Recv Req REGISTER from 192.168.1.184:5060 tid=68319410
[email protected]:
Via: SIP/2.0/UDP 192.168.1.184:5060;branch=z9hG4bK68319410
Max-Forwards: 70
Contact: <sip:
To: "Tecnici" <sip:
[email protected]:5065>;tag=2479816093
Call-ID:
[email protected]
CSeq: 15342 REGISTER
Expires: 120
Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE
Proxy-Authorization: Digest username="of8oFwFalL",realm="3CXPhoneSystem",nonce="414d53595fc9075d80:dcf8b59fdf3e404879cfef8888f85b3b",uri="sip:192.168.1.175:5065",response="996e12ffdbae6ba98fce25bbcb1661c3",algorithm=MD5
User-Agent: Yealink W60B 77.83.0.85 805ec0d0fed7
Allow-Events: talk, hold, conference, refer, check-sync
Content-Length: 0
03/12/2020 16:42:20 - Updating device Dev(1255578600):[sip:
[email protected]:5483;rinstance=baecb746d10a7e27 / 700] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5483 tid=28b6e566dbfbb53f Call-ID=g1Kk_qGLfd6fWg9jSRUmMA..:
REGISTER sip:127.0.0.1:5065 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---28b6e566dbfbb53f;rport=5483
Max-Forwards: 70
Contact: <sip:
[email protected]:5483;rinstance=baecb746d10a7e27>
To: "Conference Room700:"<sip:
[email protected]:5065>;tag=1c488d55
Call-ID: g1Kk_qGLfd6fWg9jSRUmMA..
CSeq: 16936 REGISTER
Expires: 60
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="700",realm="3CXPhoneSystem",nonce="414d53595fc9075c71:bb0906a9d25561b0fbb651c17cd0167b",uri="sip:127.0.0.1:5065",response="78735a1c4608b3621aac6b99fbaf9380",algorithm=MD5
Supported: replaces
User-Agent: 3CX Conference Room
Content-Length: 0
03/12/2020 16:42:20 - Cancelled L:369.4[Extn:006] by reason SIP ;cause=487 ;text="Request terminated, time out"
03/12/2020 16:42:20 - Cancelled L:369.3[Extn:006] by reason SIP ;cause=487 ;text="Request terminated, time out"
03/12/2020 16:42:20 - Cancelled L:369.2[Extn:001] by reason SIP ;cause=487 ;text="Request terminated, time out"
03/12/2020 16:42:18 - CSTA: on info success: CSTA Recv 200/INFO from 192.168.1.169:5060 tid=5353cc1f24bf533a Call-ID=ElNEtzZRZP7YZPZ4S3lo4A..:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.175:5065;branch=z9hG4bK-524287-1---5353cc1f24bf533a;rport=5065
Contact: <sip:
To: <sip:
CSeq: 1883 INFO
MAC: 0c:38:3e:03:45:26
Content-Length: 265
03/12/2020 16:42:18 - CSTA: onReadyToSend: CSTA Send Req INFO from 0.0.0.0:0 tid=55c53619dbaa4113 Call-ID=ElNEtzZRZP7YZPZ4S3lo4A..:
INFO sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---55c53619dbaa4113;rport
Max-Forwards: 70
Contact: <sip:001>
To: <sip:
CSeq: 1883 INFO
Content-Length: 208
</SnapshotDevice>
03/12/2020 16:42:17 - [CM503025]: Call(C:369): Calling T:VMail:999@[Dev:sip:
[email protected]:5483;rinstance=8b4eeb4413c542f9] for L:369.1[Line:10002<<04319xxxx]
03/12/2020 16:42:17 - Route to L:369.5[VMail:999] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=6af86e5d4fb47669 Call-ID=Bz7mkJz2IY1GlzW2_qFt-w..:
INVITE sip:
[email protected]:5483;rinstance=8b4eeb4413c542f9 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---6af86e5d4fb47669;rport
Max-Forwards: 70
Contact: <sip:
CSeq: 1 INVITE
Alert-Info: <
http://www.notused.invalidtld>;info=external
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
Content-Length: 420
v=0
o=3cxPS 11385534291116032 8842014745427969 IN IP4 127.0.0.1
s=3cxPS Audio call
c=IN IP4 127.0.0.1
t=0 0
m=audio 7256 RTP/AVP 0 8 9 3 18 112 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:112 opus/48000/2
a=fmtp:112 maxplaybackrate=16000;sprop-maxcapturerate=16000
a=sendrecv
03/12/2020 16:42:17 - SLA is globally disabled
03/12/2020 16:42:17 - Added leg L:369.5[VMail:999]
03/12/2020 16:42:17 - ~Target=RingAll800[Ext.001,Ext.006]
03/12/2020 16:42:17 - [Flow] Call(C:369): making call from L:369.1[Line:10002<<04319xxxx] to T:VMail:999@[Dev:sip:
03/12/2020 16:42:17 - [CM503005]: Call(C:369): Forwarding: T:VMail:999@[Dev:sip:
03/12/2020 16:42:17 - [Flow] L:369.1[Line:10002<<04319xxxx]: Build targets for VMail:999
03/12/2020 16:42:17 - [Flow] Endpoint VMail:999 has no forwarding rule on reason 'All calls'
03/12/2020 16:42:17 - L:369.1[Line:10002<<04319xxxx] forwards call from RingAll:800 to VMail:999 based on rule
03/12/2020 16:42:17 - [Flow] Target endpoint for 000 is VMail:999
03/12/2020 16:42:17 - [Flow] Building VoiceMail target of endpoint 000 from "c***r DI TESTA
di tixxxxx mon***" <sip:04319xxxx@v****.my3cx.it:5065>
03/12/2020 16:42:17 - [Flow] Current call diversion path:[]
03/12/2020 16:42:17 - L:369.1[Line:10002<<04319xxxx] failed to reach RingAll:800, reason No Answer
03/12/2020 16:42:17 - RerouteReq
03/12/2020 16:42:16 - MWI.SrvSubscr(393){
[email protected]:5065}Ready to send: MWI Send Req NOTIFY from 0.0.0.0:0 tid=f48e362989fbbd59
[email protected]:
NOTIFY sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---f48e362989fbbd59;rport
Max-Forwards: 70
Contact: <sip:006>
To: "Tecnici"<sip:
[email protected]:5065>;tag=2444422548
[email protected]:5065>;tag=c7881a58
Call-ID:
[email protected]
CSeq: 2567 NOTIFY
Content-Type: application/simple-message-summary
Subscription-State: active;expires=478
Event: message-summary
Content-Length: 42
Messages-Waiting: no
voice-message: 0/0
03/12/2020 16:42:16 - MWI.SrvSubscr(288310){
[email protected]:5065}Ready to send: MWI Send Req NOTIFY from 0.0.0.0:0 tid=6539fd2b3a0ee43c
[email protected]:
NOTIFY sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---6539fd2b3a0ee43c;rport
Max-Forwards: 70
Contact: <sip:006>
To: "Tecnici"<sip:
[email protected]:5065>;tag=1409647163
[email protected]:5065>;tag=53c08607
Call-ID:
[email protected]
CSeq: 81 NOTIFY
Subscription-State: active;expires=900
Content-Length: 42
voice-message: 0/0
[email protected]:5065}Ready to send: MWI Send 200/SUBSCRIBE from 0.0.0.0:0 tid=5576729167524458880
[email protected]:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.1.163:5060;branch=z9hG4bK5576729167524458880;rport=5060
Contact: <sip:006>
To: <sip:
Call-ID:
[email protected]
CSeq: 160 SUBSCRIBE
Expires: 900
Content-Length: 0
03/12/2020 16:42:12 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:42:11 - Updating device Dev(1299709188):[sip:
[email protected]:5063;rinstance=87d801a078a1bcd4 / 90000] by message: DevUpd Recv Req REGISTER from 127.0.0.1:5063 tid=e70a454ebfcc3627 Call-ID=Z_rgZBKe6pLuqyBrp1o-jQ..:
Via: SIP/2.0/UDP 127.0.0.1:5063;branch=z9hG4bK-524287-1---e70a454ebfcc3627;rport=5063
Max-Forwards: 70
Contact: <sip:
[email protected]:5063;rinstance=87d801a078a1bcd4>
To: <sip:
[email protected]:5065>;tag=d1238f3d
Call-ID: Z_rgZBKe6pLuqyBrp1o-jQ..
CSeq: 16918 REGISTER
Expires: 60
Proxy-Authorization: Digest username="90000",realm="3CXPhoneSystem",nonce="414d53595fc9075324:d0fc625302dc054a5475886a28fc9e80",uri="sip:127.0.0.1:5065",response="cdf82c71c1f933dcec47a116fff4dd63",algorithm=MD5
Supported: replaces
User-Agent: 3CX WebRTC proxy
Content-Length: 0
03/12/2020 16:42:11 - Line 90000 got Device: Dev(1299709188):[sip:
03/12/2020 16:42:11 - Source is identified as trunk Lc:90000(@WebMeeting bridge[<sip:
[email protected]:5063/UDP>])
03/12/2020 16:42:04 - Currently active calls - 1: [369]
03/12/2020 16:42:01 - Default best-route IP is determined as 192.168.1.175
03/12/2020 16:41:57 - [CM503025]: Call(C:369): Calling T:RingAll:800@[Dev:sip:
[email protected]:5060,Dev:sip:
[email protected]:5060] for L:369.1[Line:10002<<04319xxxx]
03/12/2020 16:41:57 - Route to L:369.4[Extn:006] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=13eb211955506e4f Call-ID=VbGmSip_UNCnf15mIMB2tA..:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---13eb211955506e4f;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1 INVITE
Alert-Info: <
Content-Length: 428
v=0
o=3cxPS 4965590133374976 24435517005234177 IN IP4 192.168.1.175
s=3cxPS Audio call
c=IN IP4 192.168.1.175
t=0 0
m=audio 7254 RTP/AVP 0 8 9 3 18 112 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=sendrecv
03/12/2020 16:41:57 - SLA is globally disabled
03/12/2020 16:41:57 - Added leg L:369.4[Extn:006]
03/12/2020 16:41:57 - Route to L:369.3[Extn:006] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=821f5c461fe5481b Call-ID=Cpm1yw4HGM4rU2et7y83aQ..:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---821f5c461fe5481b;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1 INVITE
Alert-Info: <
Content-Length: 428
v=0
o=3cxPS 22243034095681536 6949684367065089 IN IP4 192.168.1.175
s=3cxPS Audio call
t=0 0
m=audio 7252 RTP/AVP 0 8 9 3 18 112 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=sendrecv
03/12/2020 16:41:57 - Created new call info (connection): CstaConn{pcid=,caller=04319xxxx,C:369.3;connst=}
03/12/2020 16:41:57 - Added leg L:369.3[Extn:006]
03/12/2020 16:41:57 - Route to L:369.2[Extn:001] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=95bee50361d0e960 Call-ID=_GMVM_VbU0GA5x2Dh_BP3w..:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---95bee50361d0e960;rport
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 1 INVITE
Alert-Info: <
Content-Length: 429
v=0
o=3cxPS 29402602206658560 12642694840975361 IN IP4 192.168.1.175
s=3cxPS Audio call
t=0 0
m=audio 7250 RTP/AVP 0 8 9 3 18 112 101
a=rtpmap:3 GSM/8000
a=fmtp:18 annexb=no
a=sendrecv
03/12/2020 16:41:57 - Created new call info (connection): CstaConn{pcid=,caller=04319xxxx,C:369.2;connst=}
03/12/2020 16:41:57 - Added leg L:369.2[Extn:001]
03/12/2020 16:41:57 - [Flow] Call(C:369): making call from L:369.1[Line:10002<<04319xxxx] to T:RingAll:800@[Dev:sip:
03/12/2020 16:41:57 - [CM503027]: Call(C:369): From: Line:10002<<04319xxxx ("c***r DI TESTA
di tixxxxx mon***" <sip:04319xxxx@v****.my3cx.it:5065>) to T:RingAll:800@[Dev:sip:
03/12/2020 16:41:57 - [CM503004]: Call(C:369): Route 1: from L:369.1[Line:10002<<04319xxxx] to T:RingAll:800@[Dev:sip:
03/12/2020 16:41:57 - [Flow] Endpoint Extn:006 has no forwarding rule on reason 'All calls'
03/12/2020 16:41:57 - [Flow] Target endpoint for 006 is Extn:006
03/12/2020 16:41:57 - [Flow] Building target endpoint to 006 from "c***r DI TESTA
03/12/2020 16:41:57 - [Flow] Endpoint Extn:001 has no forwarding rule on reason 'All calls'
03/12/2020 16:41:57 - [Flow] Target endpoint for 001 is Extn:001
03/12/2020 16:41:57 - [Flow] Building target endpoint to 001 from "c***r DI TESTA
03/12/2020 16:41:57 - [Flow] Call(C:369): has built target endpoint: RingAll:800 for call from L:369.1[Line:10002<<04319xxxx]
03/12/2020 16:41:57 - [Flow] Target endpoint for 800 is RingAll:800
03/12/2020 16:41:57 - [Flow] Building target endpoint to 800 from "c***r DI TESTA
03/12/2020 16:41:57 - [CM503010]: Call(C:369): Making route(s) from Line:10002<<04319xxxx to <sip:
[email protected]:5065/UDP>
03/12/2020 16:41:57 - Remote SDP is set for leg L:369.1[Line:10002<<04319xxxx]
03/12/2020 16:41:57 - [CM505002]: Gateway:[Patton 04313xxxx] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4112 JO EUI 00A0BA10A5BA R6.11 2019-07-02 H323 SIP FXS FXO M5T SIP Stack/4.2.26.112] PBX contact: [sip:
[email protected]:5065]
03/12/2020 16:41:57 - Inbound DID: ''; Phonebook Name: 'c***r DI TESTA
di tixxxxx mon***'
03/12/2020 16:41:57 - [CM500002]: Call(C:369): Info on incoming INVITE from Line:10002<<04319xxxx:
Invite-IN Recv Req INVITE from 192.168.1.173:5060 tid=19601125f656579ec Call-ID=6c516c727ab31ef1:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
[email protected]:5060;transport=udp>
To: <sip:
CSeq: 9268 INVITE
Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, INFO, UPDATE, REFER, REGISTER
Proxy-Authorization: Digest username="10002",realm="3CXPhoneSystem",nonce="414d53595fc9074518:cfdfc7635131374ec0711e84d6e4aefa",uri="sip:
[email protected]:5065",response="b11ef5f2e1f2b0d301ffac1bcbff56e2",algorithm=MD5
Supported: replaces
User-Agent: Patton SN4112 JO EUI 00A0BA10A5BA R6.11 2019-07-02 H323 SIP FXS FXO M5T SIP Stack/4.2.26.112
Content-Length: 248
v=0
o=MxSIP 0 183 IN IP4 192.168.1.173
s=SIP Call
c=IN IP4 192.168.1.173
t=0 0
m=audio 5032 RTP/AVP 0 8 18 101
a=fmtp:101 0-16
a=sendrecv
03/12/2020 16:41:57 - [CM503001]: Call(C:369): Incoming call from Line:10002<<04319xxxx to <sip:
03/12/2020 16:41:57 - Line limit check: Current # of calls for line Lc:10002(@Patton 04313xxxx[<sip:
[email protected]:5060/UDP>]) is 1; limit is 4
03/12/2020 16:41:57 - Blacklist check: number '04319xxxx', list: ''; result = false
03/12/2020 16:41:57 - Updating device Dev(1739829191):[sip:
[email protected]:5060 / 10002] by message: DevUpd Recv Req INVITE from 192.168.1.173:5060 tid=19601125f656579ec Call-ID=6c516c727ab31ef1:
INVITE sip:
Max-Forwards: 70
Contact: <sip:
To: <sip:
CSeq: 9268 INVITE
Supported: replaces
Content-Length: 248
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=sendrecv
03/12/2020 16:41:57 - [CM503012]: Inbound office hours rule (unnamed) for 10002 forwards to DN:800
03/12/2020 16:41:57 - [Flow] Looking for inbound target: called=000000; caller="c***r DI TESTA
di tixxxxx mon***" <sip:04319xxxx@:0>
03/12/2020 16:41:57 - CallerNameAddr: "c***r DI TESTA
di tixxxxx mon***"<sip:04319xxxx;nf=e>
03/12/2020 16:41:57 - PBSubst: 04319xxxx => c***r DI TESTA
di tixxxxx mon***(1 matches found)
03/12/2020 16:41:57 - No inbound caller ID reformat rule for DN:10002 is defined, or it is disabled (<Rules />)
03/12/2020 16:41:57 - Source is identified as trunk Lc:10002(@Patton 04313xxxx[<sip:
03/12/2020 16:41:57 - IncomingCall: C:369 from <sip:
[email protected]:5060/UDP> to <sip:
03/12/2020 16:41:57 - Added leg L:C:369.1[No endpoint yet]
03/12/2020 16:41:57 - Call from <sip:
