Salve sto cercando di configurare lo spa 3000 con il centralino 3cx versione free.
Il centralino per prove è installato su win 7 64 bit.
Lo spa 3000 ha IP: 192.168.1.20
Ho configurato i vari interni così come da guida.
soltanto che non riesco a fare ne chiamate ne a riceverle.
quando provo a farle nel logo ho questo.
20-08-2012 20:15:35.461 Leg L:15.1[Extn:100] is terminated: Cause: 200 BYE from PBX
20-08-2012 20:15:35.428 [CM503020]: Call(C:15): Normal call termination. Call originator: Extn:100. Reason: Not found
20-08-2012 20:15:35.428 [CM503016]: Call(C:15): Attempt to reach from Extn:100 has failed. Reason: Not Found
20-08-2012 20:15:35.428 [CM503014]: Call(C:15): No known route from Extn:100 to target:
20-08-2012 20:15:35.426 [CM503001]: Call(C:15): Incoming call from Extn:100 to
20-08-2012 20:06:36.589 Leg L:14.1[Extn:100] is terminated: Cause: 200 BYE from PBX
20-08-2012 20:06:36.570 [CM503020]: Call(C:14): Normal call termination. Call originator: Extn:100. Reason: Not found
20-08-2012 20:06:36.570 [CM503016]: Call(C:14): Attempt to reach from Extn:100 has failed. Reason: Not Found
20-08-2012 20:06:36.569 [CM503014]: Call(C:14): No known route from Extn:100 to target:
20-08-2012 20:06:36.567 [CM503001]: Call(C:14): Incoming call from Extn:100 to
20-08-2012 20:05:36.885 Leg L:13.1[Extn:100] is terminated: Cause: 200 BYE from PBX
20-08-2012 20:05:36.852 [CM503020]: Call(C:13): Normal call termination. Call originator: Extn:100. Reason: Not found
20-08-2012 20:05:36.852 [CM503016]: Call(C:13): Attempt to reach from Extn:100 has failed. Reason: Not Found
20-08-2012 20:05:36.852 [CM503014]: Call(C:13): No known route from Extn:100 to target:
20-08-2012 20:05:36.850 [CM503001]: Call(C:13): Incoming call from Extn:100 to
20-08-2012 20:03:29.203 Leg L:12.1[Extn:100] is terminated: Cause: 200 BYE from PBX
Da cosa dipende??
Grazie a tutti quelli che mi dedicheranno del tempo.
ps. nel campo proxy del spa 3000 che ip devo mettere??
attualmente è presente 192.168.1.133 che sarebbe quello dove si registrano i vari telefoni interni
Da cosa dipende??
