Problema mancata disconnessione chiamate
sto cercando di configurare un nuovo centralino 3CX con dei telefoni SIP VoiSmart 107 (vecchio modello) con firmware v01.20.02.
Purtroppo quando riaggancio sui telefoni la chiamata non viene disconnessa!
Provo a postare un log preso da 3CX:
27-dic-2012 17:01:13.291 [CM503007]: Call(C:89): Extn:401 has joined, contact
27-dic-2012 17:01:13.288 L:89.2[Extn:401] has joined to L:89.1[Extn:714]
27-dic-2012 17:01:13.288 Session 2721 of leg L:89.2[Extn:401] is connected
27-dic-2012 17:01:13.288 L:89.2[Extn:401] got Connected.UAC Recv 200/INVITE from 192.168.252.141:5060 tid=e70fd901de273f35 Call-ID=NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.251.5:5060;branch=z9hG4bK-d8754z-e70fd901de273f35-1---d8754z-;rport
Contact:
To: ;tag=00D0E940E1BD_T1721695711
Call-ID: NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.
CSeq: 1 INVITE
Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, REFER, DO, UPDATE, OPTIONS, SUBSCRIBE, PRACK, INFO
Content-Type: application/sdp
Supported: 100rel, timer, replaces
Content-Length: 176
v=0
o=401 2065837676 2065837676 IN IP4 192.168.252.141
s=VOIP P170SLD 01.20.02
c=IN IP4 192.168.252.141
t=0 0
m=audio 41000 RTP/AVP 0
a=rtpmap:0 PCMU/8000/1
a=sendrecv
27-dic-2012 17:01:13.288 Remote SDP is set for leg L:89.2[Extn:401]
27-dic-2012 17:01:13.288 Answer SDP arrived on Leg L:89.2[Extn:401];
OnAnswer Recv 200/INVITE from 192.168.252.141:5060 tid=e70fd901de273f35 Call-ID=NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.:
SIP/2.0 200 OK
Contact:
CSeq: 1 INVITE
Content-Length: 176
v=0
t=0 0
a=sendrecv
27-dic-2012 17:01:13.288 L:89.2[Extn:401] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=39474461f846b034 Call-ID=NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.:
ACK sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-39474461f846b034-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 1 ACK
Content-Length: 0
27-dic-2012 17:01:12.282 Provisional response arrived for session 2721 of Leg L:89.2[Extn:401]
27-dic-2012 17:01:12.282 L:89.2[Extn:401] got Provisional Recv 180/INVITE from 192.168.252.141:5060 tid=e70fd901de273f35 Call-ID=NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.:
SIP/2.0 180 Ringing
Contact:
CSeq: 1 INVITE
User-Agent: VOIP P170SLD 01.20.02
Content-Length: 0
27-dic-2012 17:01:12.282 [CM505001]: Endpoint Extn:401: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [VOIP P170SLD 01.20.02] PBX contact: [sip:[email protected]:5060]
27-dic-2012 17:01:12.282 [CM503002]: Call(C:89): Alerting Extn:401 by contact
27-dic-2012 17:01:12.281 UacSession 2721 has formed leg L:89.2[Extn:401]
27-dic-2012 17:01:12.000 [CM503025]: Call(C:89): Calling T:Extn:401@[Dev:sip:[email protected]:5060] for L:89.1[Extn:714]
27-dic-2012 17:01:12.000 Route to L:89.2[Extn:401] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=d469677427446f3e Call-ID=NmIyMDk4NjZlMjlmOWIxNGYyMWViYTlkYmIzMzdiOGE.:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-d469677427446f3e-1---d8754z-;rport
Max-Forwards: 70
Contact:
To:
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
Content-Length: 406
v=0
o=3cxPS 511705088000 210218516481 IN IP4 192.168.251.5
s=3cxPS Audio call
c=IN IP4 192.168.251.5
t=0 0
m=audio 7392 RTP/AVP 0 8 3 13 9 18 110 99 101
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:110 iLBC/8000
a=rtpmap:99 SPEEX/8000
a=sendrecv
27-dic-2012 17:01:11.997 Added leg L:89.2[Extn:401]
27-dic-2012 17:01:11.952 [Flow] Call(C:89): making call from L:89.1[Extn:714] to T:Extn:401@[Dev:sip:[email protected]:5060]
27-dic-2012 17:01:11.952 [CM503027]: Call(C:89): From: Extn:714 ("RECEPTION-1" ) to T:Extn:401@[Dev:sip:[email protected]:5060]
27-dic-2012 17:01:11.952 [CM503004]: Call(C:89): Route 1: from L:89.1[Extn:714] to T:Extn:401@[Dev:sip:[email protected]:5060]
27-dic-2012 17:01:11.952 [Flow] Endpoint Extn:401 has no forwarding rule on reason 'All calls'
27-dic-2012 17:01:11.952 [Flow] Call(C:89): has built target endpoint: Extn:401 for call from L:89.1[Extn:714]
27-dic-2012 17:01:11.952 [Flow] Target endpoint for 401 is Extn:401
Qualcuno potrebbe darmi una mano?
Grazie!
Purtroppo il telefono non è supportato. Dovresti provare ad aggiornare il firmware e vedere se qualcosa cambia. E' verosimile che il prodotto utilizzi un firmware proprietario destinato ad essere utilizzato con una versione specifica di PBX.
In alternativa ti conviene optare per un hardware certificato e compatibile.
