Release 7.1 DEFINITIVA
eurylink.com
Gold Partner
Riporto gli AGGIORNAMENTI:
Build Version 7.1.6589 17 April 2009 (RC4)
* Updated License activation module - required for activation of license keys
* Added: Wrapping of text in Exchange page of management console
* Added: DORO phone template
* Added: Call Reporter now shows costs for each call made rounded to 2 Decimal Places
* Fixed: Improved Patton FXO templates - Added hunting options and improved call end detection (resolves completely stuck call issues)
* Fixed: Billing rate not applied for calls that are not answered (depending on whether gateway has early media enabled)
* fixed: Fix in Backup and restore to remove billing entries in Database that were unnecessary
* Fixed: Bug in Default billing code - new rate was not applied correctly
* Fixed: A situation could occur that when deleting a DID, other DIDs could be effected
* Fixed: Call Assistant Server would sometimes continue displaying calls that had been ended
* KNOWN ISSUE: Costs apportioned to calls made on previous versions may not be accurate
* KNOWN ISSUE: DID problem may persist after backup and restore of a version with effected DIDs - in this case just go to port to which the DID applies and click Apply
Per il download:
https://www.3cx.com/phone-system/downloadlinks_a5f8hyd937/
Matteo,
dagli ultimi sviluppi non ritengo sia l'ultima (RC4 ...) indipendentemente da quanto affermato dal blog di N.Galea quale 'official release'.
Sorry, ma noi rimaniamo con la 6.1 fino a nuovi annunci.
Onestamente penso che i passi avanti con la 7 siano molto positivi, ma insufficienti per avere un soft PBX stabile e completo.
Mi riprometto di testare la 7.1 quando TUTTI saranno soddisfatti.
Voi che ne pensate?
Ciao.
Ciao Matteo e grazie per la comunicazione.
Visto che ho una versione precedente (la Rc2), bisogna fare qualcosa di particolare per l'upgrade (a parte ovviamente salvare la configurazione e poi ricaricarla) ?
Per quanto riguarda il punto : "* Updated License activation module - required for activation of license keys",visto che io ho una versiona licenziata, bisogna riattivare la licenza ?
Negli aggiornamenti che ho eseguito è stato sufficiente fare il backup e ripristinare. Nei miei casi non è stato necessario riattivare la licenza.
Procedura:
1) Bacup
2) Disintallazione RC2
3) riavvio Server
4) Installazione RC4
5) Ripristino
6) Riavvio Server.
TI consiglio di eseguire i riavvii server perchè altrimenti in qualche caso potresti riscontrare problemi sui servizi.
