- 21 Ottobre 2014
E' stata rilasciata la versione 7.1 Release Candidate 1:
Riporto di seguito le correzioni apportate:
Prego tutti di postare qui i problemi e le eventuali anomalie riscontrate.
Per chi aveva problemi con la creazione di profili per i provider voip (solo su alcune installazioni) segnalo che la cosa dovrebbe essere corretta:
3CX Phone System 7.1 RC1
3CX Phone System v7.1 is nearing release - we have ironed out pretty much all remaining issues and we recommend this build. Here is the change log:
Added: Japanese Language files
Added: Gateway for the Linksys 3102 gateway with tone sets added for various countries
Added: New startup page for the Call Reporter
Added: Two additional reports - Call Statistics and Agent Statistics
Added: Call Assistant and Call History service to services page
Added: Better ring group validation
Added: Adjusted validation to allow entry of SKYPE addresses
Added: Management console will logout after 10 minutes of inactivity
Fixed: Transfers and Attended transfers to extensions on the same PBX or to extensions on the remote PBX through bridges and tunneled connections.
Fixed: RTP port leaks in Tunnel Functionality -RTP ports were being left open on the system.
Fixed: It is now possible to specify a hostname in the tunnel configuration.
Fixed: An exception could be shown when adding a VoIP provider
Fixed: Shortcuts in program group when selecting Cassini as the web server
Fixed: MyPhone Login Page closes after timeout of 10 minutes
Fixed: Myphone Busy timeout bug
Fixed: Call Reporter now saves Header and Footer of reports.
Fixed: File not found problem in Call Reporter fixed when reports.dsn file is not written.
Fixed: Call Reporter now uses Date-Month-Year setting of local machine.
Fixed: Default port for fax sending module was not correct. Has now been changed to 5487
Fixed: Call History Service is now restarted automatically after license activation
Fixed: Bug in Conference Place extension configuration.
Fixed: IVR transfer when sip port is not equal to 5060
Fixed: Wasted call license when assigning calls to an agent.
Fixed: Cache of non existent calls.
Fixed: Forwarding rules on extension would conflict with system wide Holiday settings
3CX Assistant
Added: Exception for 3CX Assistant in the Windows Firewall.
Added: Removed voicemail column
Added: Menu bar and about dialog
Added: Divert on ringing in notification window.
Added: Away and available are colour coded. Away Red, Available Green. Also Added to Menu action Drop Down
Added: All extensions can by default seel all other extensions (not details, just number)
Added: Voicemail Counter at the top
Added: The users group will be shown first in the extension list
Fixed: Rights for groups
Fixed: Caller ID Shown in Call Assistant
Downloads:
http: //www.3cx.com/downloads/3CXPhoneSystem71.exe
http: //www.3cx.com/downloads/3CXVoIPPhone3.msi
http: //www.3cx.com/downloads/3CXAssistantSetup_71.exe
http: //www.3cx.com/downloads/3CXfaxserver.msi
3CX Assistant
Downloads:
