[RISOLTO] Caller ID Ingresso
posseggo un patton 4114 su 4 linee analogiche (normali) e un centrlino 3cx.
Tutto è ok ma avrei la necessità di vedere il numero del chiamante. Questo il mio operatore (fastweb) mi conferma che avviene, ma come faccio a inoltrare il numero chiamante patton-->3cx e quindi agli apparecchi telefonici?
questa è configrazione del mio patton ma non capisco dove sia la falla... avete suggeriementi o consigli?
# SN4114/JO/EUI #
# R4.2 2007-12-03 H323 SIP FXS FXO #
# 1970-01-03T07:49:19 #
# SN/00A0BA029A38 #
# Generated configuration file #
cli version 3.20
webserver port 80 language en
system hostname 192.168.169.253
system
ic voice 0
low-bitrate-codec g729
profile ppp default
profile call-progress-tone IT_Dialtone
play 1 200 425 -12
pause 2 200
play 3 600 425 -12
pause 4 1000
profile call-progress-tone IT_Alertingtone
play 1 1000 425 -12
pause 2 4000
profile call-progress-tone IT_Busytone
play 1 500 425 -12
pause 2 500
profile tone-set default
profile tone-set IT
map call-progress-tone dial-tone IT_Dialtone
map call-progress-tone ringback-tone IT_Alertingtone
map call-progress-tone busy-tone IT_Busytone
map call-progress-tone release-tone IT_Busytone
map call-progress-tone congestion-tone IT_Busytone
profile voip default
codec 1 g711alaw64k rx-length 20 tx-length 20
codec 2 g711ulaw64k rx-length 20 tx-length 20
profile pstn default
profile sip default
profile aaa default
method 1 local
method 2 none
context ip router
interface eth0
ipaddress 192.168.169.253 255.255.255.0
context ip router
route 0.0.0.0 0.0.0.0 192.168.169.254 0
context cs switch
no digit-collection timeout
routing-table called-e164 OUT
route default dest-interface sipif0 CALLED
routing-table called-e164 OUT1
route default dest-interface sipif1 CALLED1
mapping-table called-e164 to called-e164 CALLED
map default to MIONUMEROTELEFONO
mapping-table called-e164 to called-e164 CALLED1
interface sip sipif0
bind gateway sipgw0
service default
route call dest-service fxohuntgroup
early-disconnect
remote-party-id called-party
address-translation outgoing-call from-header user-part fix 10000 host-part local-ip
address-translation incoming-call called-e164 to-header
interface sip sipif1
bind gateway sipgw1
service default
early-disconnect
address-translation outgoing-call from-header user-part fix 10001 host-part local-ip
interface sip sipif2
bind gateway sipgw2
service default
early-disconnect
address-translation outgoing-call from-header user-part fix 10002 host-part local-ip
interface sip sipif3
bind gateway sipgw3
service default
early-disconnect
address-translation outgoing-call from-header user-part fix 10003 host-part local-ip
interface fxo fxoif0
route call dest-table OUT
disconnect-signal loop-break
disconnect-signal busy-tone
ring-number on-caller-id
use profile tone-set IT
interface fxo fxoif1
route call dest-table OUT1
interface fxo fxoif2
route call dest-interface sipif2
interface fxo fxoif3
route call dest-interface sipif3
service hunt-group fxohuntgroup
drop-cause normal-unspecified
drop-cause no-circuit-channel-available
drop-cause network-out-of-order
drop-cause temporary-failure
drop-cause switching-equipment-congestion
drop-cause access-info-discarded
drop-cause circuit-channel-not-available
drop-cause resources-unavailable
drop-cause user-busy
route call 1 dest-interface fxoif0
route call 2 dest-interface fxoif1
route call 3 dest-interface fxoif2
route call 4 dest-interface fxoif3
context cs switch
no shutdown
gateway sip sipgw0
bind interface eth0 router
service default
domain 192.168.169.22
defaultserver manual 192.168.169.22 loose-router
registration manual 192.168.169.22
user 10000 authenticate password LbFCDNv4/Fk= encrypted default register
gateway sip sipgw0
no shutdown
gateway sip sipgw1
call-signaling-port 5062
service default
user 10001 authenticate password dZ8edXkjFnM= encrypted default register
gateway sip sipgw1
no shutdown
gateway sip sipgw2
call-signaling-port 5064
service default
user 10002 authenticate password iAaKwKfxX4Q= encrypted default register
gateway sip sipgw2
no shutdown
gateway sip sipgw3
call-signaling-port 5066
service default
user 10003 authenticate password ySyWxUvSc/c= encrypted default register
gateway sip sipgw3
no shutdown
port ethernet 0 0
medium auto
encapsulation ip
no shutdown
port fxo 0 0
use profile fxo us
encapsulation cc-fxo
bind interface fxoif0 switch
no shutdown
port fxo 0 1
use profile fxo us
bind interface fxoif1 switch
no shutdown
port fxo 0 2
use profile fxo us
bind interface fxoif2 switch
no shutdown
port fxo 0 3
use profile fxo us
bind interface fxoif3 switch
no shutdown
Se ritieni che la configurazione sia corretta (e credo lo sia visto che ricevi le telefonata), ti rispondo per la medesima situazione in ambiente Telecom: su 3 impianti diversi con il Patton 4114, appena attaccavo le uscite, improvvisamente il caller ID mi diventava anonimo. Ho attaccato quindi alla borchia un normale telefono, composto il codice per l'attivazione del servizio "chi è" e tutto si è risolto.
Potrebbe essere uno spunto di risoluzione anche del tuo problema?? Ovviamente accertati tramite il tuo operatore di telefonia su qual è il codice per lo sblocco
Problema risolto sul patton, non rigirava correttamente il caller ID, è bastato rigenerare la configurazione dal server 3cx e tutto si è risolto.
puoi mettere un bel [RISOLTO] sul titolo del primo post? aiuta!! :mrgreen:
