[RISOLTO] Chiamata vietata dall'amministratore
kmaxmax
All'improvviso non raggiungo piu' questo numero... 07xxxxxxxx
- Regole di uscita corrette
- Template ricaricato
- Centralino reinstallato
- Qualunque altra chiamata và
Possibile che sia bloccato il numero che voglio raggiungere lato provider ?? ( 83.211.227.21 = voip.eutelia.it )
13:05:43.877 [CM503003]: Call(145): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:83.211.227.21:5060
13:05:47.205 [CM503008]: Call(145): Call is terminated
13:05:44.111 [CM503007]: Call(145): Device joined: sip:[email protected]:40600;rinstance=aac7b6902d150238
13:05:44.111 [CM503007]: Call(145): Device joined: sip:[email protected]:2049;line=jcvsa9hp
13:05:44.080 [CM503002]: Call(145): Alerting sip:[email protected]:40600;rinstance=aac7b6902d150238
13:05:43.908 [CM503025]: Call(145): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=aac7b6902d150238]
13:05:43.893 [CM503016]: Call(145): Attempt to reach failed. Reason: Forbidden
13:05:39.893 [CM503025]: Call(145): Calling VoIPline:0xxxxxxxx@(Ln.10002@ActiveNetwork 102)@[Dev:sip:[email protected]:5060]
13:05:39.877 [CM503003]: Call(145): Call to sip:[email protected]:5060 has failed; Cause: 403 Forbidden; from IP:83.211.227.21:5060
13:05:35.705 [CM503025]: Call(145): Calling VoIPline:0xxxxxxxx@(Ln.10001@ActiveNetwork 136)@[Dev:sip:[email protected]:5060]
13:05:35.689 [CM503004]: Call(145): Route 2: VoIPline:0xxxxxxxx@(Ln.10002@ActiveNetwork 102)@[Dev:sip:[email protected]:5060]
13:05:35.689 [CM503004]: Call(145): Route 1: VoIPline:0xxxxxxxx@(Ln.10001@ActiveNetwork 136)@[Dev:sip:[email protected]:5060]
13:05:35.674 [CM503010]: Making route(s) to
13:05:35.658 [CM505001]: Ext.15: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom300/7.3.30] PBX contact: [sip:[email protected]:5060]
13:05:35.643 [CM503001]: Call(145): Incoming call from Ext.15 to
Scoperto l'arcano:
Incredibile ma vero.... il chiamato avea una linea voip e aveva spento il router....
Vabbeh.. :roll:
