Risultato Test Firewall
Ho lanciato il test del firewall ed ho ottenuto il seguente risultato:
Qualcuno mi può aiutare ad interpretarlo? Ho effettuato alcuni settaggi sul router ho provato anche a disabilitare anche il firewall interno del router, a fare ldelle port forwarding ma il risultato non cambia mai....
3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
: Phase 1, checking servers connection, please wait...
: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 10000::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 10000::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
: TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 10001::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: Phase 4. Check Port Forwarding to RTP external port range, please wait...
: UDP RTP Port 9000. Response received WITH TRANSLATION 10002::9000. Phase 4-01 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: UDP RTP Port 9001. Response received WITH TRANSLATION 10003::9001. Phase 4-02 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: UDP RTP Port 9002. Response received WITH TRANSLATION 10004::9002. Phase 4-03 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: UDP RTP Port 9003. Response received WITH TRANSLATION 10005::9003. Phase 4-04 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
Giovanni
Ciao genialwebit
Analizzaqndo la tua domanda vorei aggiungere altre considerazioni:
1)Ho avuto anch'io questo tipo di problema nonostante ho i tuoi stessi risultati nel test del firewall tutto sembra funzionare abbastanza bene a questo punto mi chiedo a cosa serve aprire queste porte?
2)Perchè è necessario che siano aperte sul router?
3)Ho provato su 2 router differenti e nonostante ho forwardato le porte sull'IP del server 3cx il risultato non cambia, qui credo che sia un problema di router non saprei dire quale problema in quanto se apro le porte per Emule il tutto funziona correttamente ovvero l'ID mi va com alto, invece se apro le porte su 3cx o le lascio chiuse il test rimane invariato come hai descritto tu genialwebit, è anche vero che una volta ho letto un post in cui un nostro amico aveva mappato le porte su un router cisco e il test gli dava passed in tutte le sue fasi.
A questo punto dico in conclusione:
1) C'è qualcuno che sa spiegare in modo chiaro perchè le porte devono essere aperte?
2) Qual'è la differenza tra Virtual server, Port Forward,ed altri tracchiggi per aprire le porte sui router forse il problema sta prorio qui?
Max
