Test Firewall
Che ne pensate?
3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
: Phase 1, checking servers connection, please wait...
: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 49153::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 49153::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit https://www.3cx.com/blog/docs/firewall-checker/
: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
: Phase 4. Check Port Forwarding to RTP external port range, please wait...
: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
Se chiamo i miei numeri non sento squillare i grandstream collegati alla rete!
aiuti?
Sono un novellino
Ho 2 numeri eutelia.
Essi vengono registrati correttamente.
Solo se chiamo i miei numeri sento il segnale del libero.
I telefoni sono stati configurati correttamente
Ho questo telefono
BudgeTone 200 (BT200)
Riprovato a chiamare e cosa ottengo?
Informazione gratuita - Il numero da lei chiamato è temporaneamente indisponibile
Help me!
Provato a montare anche il telefono di 3cxp, quello virtuale ma non squilla!
Ragazzi vi chiedo immensamente aiuto!
Qua' sto' ricevendo i peggiori insulti dal mio capo.
