Transito chiamate tra due Trunk SIP
Gelax
24 Giugno 2021
ho un faxserver connesso in trunk SIP con il 3CX, non riesco ad instradare le chiamate uscenti del Faxserver verso il trunk SIP di BT, esite una configurazione specifica per consentire il transito delle chiamate tra trunk (modalità ponte).
Fax Server <---- trunk SIP ----> 3cx < ---trunk SIP----> Operatore BT
Grazie, Marco
Hello,
Which fax server/gateway are you using?
Normally one would register his fax gateway as a fax extension (which are meant to handle audio and T.38 faxes) then you can route outbound calls from the fax extension to your BT trunk.
I use Imagicle StoneFAX, only SIP trunk without autentication is supported, infact i can't use brigde mode (master/Slave).
