chiedo venia, effettivamente e' questo il log della chiamata dal 373 al 112:
05-ago-2013 15:58:59.459 Reneg. from L:2365.2[Extn:373], answer
05-ago-2013 15:58:59.459 Leg L:2365.2[Extn:373] raised event RecvdRemoteSdp
05-ago-2013 15:58:59.459 Remote SDP is set for leg L:2365.2[Extn:373]
05-ago-2013 15:58:59.459 NAT/ALG check:L:2365.2[Extn:373] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
05-ago-2013 15:58:59.459 Answer SDP arrived on Leg L:2365.2[Extn:373];
OnAnswer Recv 200/INVITE from 10.0.0.58:37270 tid=d115204bf155fd5e Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.0.0.20:5060;branch=z9hG4bK-d8754z-d115204bf155fd5e-1---d8754z-;rport=5060
Contact: ;reg-id=1
To: "Interno373";tag=qy17eigsf6;intercom=true
Call-ID: ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.
CSeq: 3 INVITE
Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO, UPDATE
Content-Type: application/sdp
Supported: timer, 100rel, replaces, from-change
User-Agent: snomMP/8.7.3.19
Allow-Events: talk, hold, refer, call-info
Content-Length: 222
v=0
o=root 1095448753 1095448756 IN IP4 10.0.0.58
s=call
c=IN IP4 10.0.0.58
t=0 0
m=audio 63558 RTP/AVP 0 101
a=rtpmap:0 pcmu/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
05-ago-2013 15:58:59.459 L:2365.2[Extn:373] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=1b09214fa2507b6b Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
ACK sip:
[email protected]:37270;line=5smqrd1w SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-1b09214fa2507b6b-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 3 ACK
Content-Length: 0
05-ago-2013 15:58:59.291 L:2365.2[Extn:373] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=c60bc7022b562456 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-c60bc7022b562456-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 3 INVITE
Alert-Info: ;info=ivr
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Call-Info: ;answer-after=0
Supported: replaces
User-Agent: 3CXPhoneSystem 11.0.28976.849 (28862)
Content-Length: 387
v=0
o=3cxPS 340543930368 25014829058 IN IP4 10.0.0.20
s=3cxPS Audio call
c=IN IP4 10.0.0.20
t=0 0
m=audio 7364 RTP/AVP 0 8 3 13 9 110 99 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:9 G722/8000
a=rtpmap:110 iLBC/8000
a=rtpmap:99 SPEEX/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
05-ago-2013 15:58:59.288 Providing SDP for L:2365.2[Extn:373]
05-ago-2013 15:58:58.958 L:2365.2[Extn:373]: Updated OutCID: '' and DNName: 'Interno373'
05-ago-2013 15:58:58.958 [CM503016]: Call(C:2365): Attempt to reach from Extn:373 has failed. Reason: Busy
05-ago-2013 15:58:58.958 [Flow] Call(C:2365): has built target endpoint: EndCall:EndCall for call from L:2365.2[Extn:373]
05-ago-2013 15:58:58.958 [Flow] Call(C:2365): Transferring endpoint is Extn:373
05-ago-2013 15:58:58.958 [CM503010]: Call(C:2365): Making route(s) from Extn:373 to
05-ago-2013 15:58:58.714 Reneg. from L:2365.2[Extn:373], answer
05-ago-2013 15:58:58.714 Leg L:2365.2[Extn:373] raised event RecvdRemoteSdp
05-ago-2013 15:58:58.714 Remote SDP is set for leg L:2365.2[Extn:373]
05-ago-2013 15:58:58.714 NAT/ALG check:L:2365.2[Extn:373] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
05-ago-2013 15:58:58.714 Answer SDP arrived on Leg L:2365.2[Extn:373];
OnAnswer Recv 200/INVITE from 10.0.0.58:37270 tid=b6573f1c1f24ee47 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.0.0.20:5060;branch=z9hG4bK-d8754z-b6573f1c1f24ee47-1---d8754z-;rport=5060
Contact: ;reg-id=1
CSeq: 2 INVITE
Content-Length: 222
v=0
o=root 1095448753 1095448755 IN IP4 10.0.0.58
s=call
c=IN IP4 10.0.0.58
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=recvonly
05-ago-2013 15:58:58.714 L:2365.2[Extn:373] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=1e13db5202240139 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
ACK sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-1e13db5202240139-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 2 ACK
Content-Length: 0
05-ago-2013 15:58:58.620 L:2365.2[Extn:373] Sending: OnSendReq Send Req INVITE from 0.0.0.0:0 tid=b650a7666c790066 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
INVITE sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-b650a7666c790066-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 2 INVITE
Supported: replaces
Content-Length: 406
v=0
o=3cxPS 345677758464 378175225857 IN IP4 10.0.0.20
s=3cxPS Audio call
c=IN IP4 10.0.0.20
t=0 0
m=audio 7364 RTP/AVP 0 8 3 13 9 18 110 99 101
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=sendonly
05-ago-2013 15:58:58.617 Providing SDP for L:2365.2[Extn:373]
05-ago-2013 15:58:58.156 [CM503007]: Call(C:2365): Extn:373 has joined, contact
05-ago-2013 15:58:58.153 L:2365.2[Extn:373] has joined to L:2365.1[Ivr:MakeCall]
05-ago-2013 15:58:58.152 Session 392733 of leg L:2365.2[Extn:373] is connected
05-ago-2013 15:58:58.152 L:2365.2[Extn:373] got Connected.UAC Recv 200/INVITE from 10.0.0.58:37270 tid=d572071bec485a44 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.0.0.20:5060;branch=z9hG4bK-d8754z-d572071bec485a44-1---d8754z-;rport=5060
Contact: ;reg-id=1
CSeq: 1 INVITE
Content-Length: 222
v=0
o=root 1095448753 1095448754 IN IP4 10.0.0.58
s=call
c=IN IP4 10.0.0.58
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
05-ago-2013 15:58:58.152 Remote SDP is set for leg L:2365.2[Extn:373]
05-ago-2013 15:58:58.152 NAT/ALG check:L:2365.2[Extn:373] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
05-ago-2013 15:58:58.152 Answer SDP arrived on Leg L:2365.2[Extn:373];
OnAnswer Recv 200/INVITE from 10.0.0.58:37270 tid=d572071bec485a44 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
SIP/2.0 200 Ok
Contact: ;reg-id=1
CSeq: 1 INVITE
Content-Length: 222
v=0
s=call
c=IN IP4 10.0.0.58
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
05-ago-2013 15:58:58.152 L:2365.2[Extn:373] Sending: OnSendReq Send Req ACK from 0.0.0.0:0 tid=b5448058821b7762 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
ACK sip:
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-b5448058821b7762-1---d8754z-;rport
Max-Forwards: 70
Contact:
CSeq: 1 ACK
Content-Length: 0
05-ago-2013 15:58:58.046 Provisional response arrived for session 392733 of Leg L:2365.2[Extn:373]
05-ago-2013 15:58:58.046 L:2365.2[Extn:373] got Provisional Recv 180/INVITE from 10.0.0.58:37270 tid=d572071bec485a44 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
SIP/2.0 180 Ringing
Contact: ;reg-id=1
CSeq: 1 INVITE
Content-Length: 0
05-ago-2013 15:58:58.046 [CM505001]: Endpoint Extn:373: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snomMP/8.7.3.19] PBX contact: [sip:
[email protected]:5060]
05-ago-2013 15:58:58.046 [CM503002]: Call(C:2365): Alerting Extn:373 by contact
05-ago-2013 15:58:58.044 UacSession 392733 has formed leg L:2365.2[Extn:373]
05-ago-2013 15:58:57.860 [CM503025]: Call(C:2365): Calling T:Extn:373@[Dev:sip:
[email protected]:37270;line=5smqrd1w] for L:2365.1[Ivr:MakeCall]
05-ago-2013 15:58:57.860 Route to L:2365.2[Extn:373] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=252336108c109376 Call-ID=ODRlNWMyNmQ3MzIyOTVhNDdhYjk0NmE0ZTExMTRlZjI.:
INVITE sip:
[email protected]:37270;line=5smqrd1w;intercom=true SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-252336108c109376-1---d8754z-;rport
Max-Forwards: 70
Contact:
To: ;intercom=true
CSeq: 1 INVITE
Supported: replaces
Content-Length: 387
v=0
o=3cxPS 340543930368 25014829057 IN IP4 10.0.0.20
s=3cxPS Audio call
c=IN IP4 10.0.0.20
t=0 0
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
05-ago-2013 15:58:57.854 Added leg L:2365.2[Extn:373]
05-ago-2013 15:58:57.810 [Flow] Call(C:2365): making call from L:2365.1[Ivr:MakeCall] to T:Extn:373@[Dev:sip:
05-ago-2013 15:58:57.810 [CM503027]: Call(C:2365): From: Ivr:MakeCall ("MakeCall" ) to T:Extn:373@[Dev:sip:
05-ago-2013 15:58:57.810 [CM503004]: Call(C:2365): Route 1: from L:2365.1[Ivr:MakeCall] to T:Extn:373@[Dev:sip:
05-ago-2013 15:58:57.810 [Flow] Call(C:2365): has built target endpoint: Extn:373 for call from L:2365.1[Ivr:MakeCall]
05-ago-2013 15:58:57.810 [Flow] Target endpoint for *9373 is Extn:373
05-ago-2013 15:52:37.345 Settings of Extn:373 has been updated
05-ago-2013 15:52:37.285 Settings of Extn:373 has been updated
05-ago-2013 15:52:37.284 Settings of Extn:373 has been updated
05-ago-2013 15:52:37.225 Settings of Extn:373 has been updated
e mi sembra che tratti il 112 come interno
p.s. se una extension con le chiamate esterne disabilitate tentasse di fare il 112 verrebbe bloccato ?
