3CX Stable Version doesn't start: psql and postgresql error
AndreaPellegrin
Forum User
27 Settembre 2019
Hi everybody!
Unfortunately I can't install the stable version of 3CX on my Raspberry Pi 3B +, I really tried for days: here the error.
Codice:
pi@raspberrypi:~ $ sudo apt -t stable install 3cxpbx
Reading package lists... Done
Building dependency tree
Reading state information... Done
3cxpbx is already the newest version (16.0.3.671).
0 upgraded, 0 newly installed, 0 to remove and 110 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Yes
2Setting up 3cxpbx (16.0.3.671) ...
psql: could not connect to server: No such file or directory
    Is the server running locally and accepting
    connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
active
dpkg: error processing package 3cxpbx (--configure):
 subprocess installed post-installation script returned error exit status 2
Errors were encountered while processing:
 3cxpbx
Hoping can solve,
have a nice day, thanks.
Pellegrin A.
ciao,
sembrerebbe che tu abbia già installato la BETA su quel Raspberry....quale versione vuoi installare?
Ah, non avevo capito. Mi basta la versione stabile. Che faccio rifaccio la SD e riparto da 0?
sicuramente conviene ripartire da 0, sì.
resetta la scheda e rifai
selbermacher
