firewall check - Error (13)
ho installato il centalino dietro un Firewall NAT, alla verifica il 3CX mi restituisce un messaggio di errore 13.
Di seguito posto il log.
Mi aiutate a capire cosa significa e come risolverlo.
Grazie In anticipo
1 Error (13) The machine is on a public IP. Please check the FAQ for more information. agentAddr = yyy.yyyy.yyy.yyy:4200
2 9000 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9000 isNATAddr = 0
3 9001 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9001 isNATAddr = 0
4 9002 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9002 isNATAddr = 0
5 9003 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9003 isNATAddr = 0
6 9004 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9004 isNATAddr = 0
7 9005 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9005 isNATAddr = 0
8 9006 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9006 isNATAddr = 0
9 9007 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9007 isNATAddr = 0
10 9008 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9008 isNATAddr = 0
11 9009 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9009 isNATAddr = 0
12 9010 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9010 isNATAddr = 0
13 9011 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9011 isNATAddr = 0
14 9012 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9012 isNATAddr = 0
15 9013 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9013 isNATAddr = 0
16 9014 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9014 isNATAddr = 0
17 9015 Information (9) Port is open and can be used for calls. externalAddress = xxx.xxx.xxx.xxx:9015 isNATAddr = 0
L'installazione è su un IP pubblico.
Ho lotatto anche io per parecchio tempo.
Tuttoggi ho lo stesso msg di errore ma il PBX funziona correttamente.
1. inserisci nell'impostazione del provider Voip ->Impostazioni di registrazione->IP Specificato = tuo ip pubblico:porta (5060 o 5061)
2. Assicurati che il router sia impostato su FULL Cone NAT
3. Apri le porte necessarie come da manuale.
immagino te l'abbia già fatto,
cmq verifica di aver correttamente aperto le porte 9000-9015
a parte l'errore che problemi hai sul centralino?
riesci a chiamare/ricevere?
cosa non va?
a me il testo firewall da un errore simile
ma non ho alcun problema ne in invio ne in ricezione delle chiamate.
