reistallazione di 3cx
Ciao, ho disistallato 3cx per poter avere interni a 2 cifre, ma ora non risco a far registrare i vari interni... Ovviamente le impostazioni del router sono rimaste le stesse.
i log del server sono:
Tempo Funzione Messaggio
17:19:35.296 CallCtrl::thread [CM501008]: *** Stopped Calls Controller thread ***
17:19:23.812 CServiceModule::PreMessageLoop [CM100001]: *!* Failed to initialize Call Manager *!*
17:19:23.812 CallMgr::Initialize [CM100001]: *!* Failed to initialize SIP Stack *!*
17:19:23.812 CallMgr::Stack::Initialize [CM101002]: Can not create UDP transport on 192.168.32.1:5062
17:19:23.812   ResipLogger:Failed to create transport: V4 UDP 5062 on 192.168.32.1
17:19:23.812   ResipLogger:[ V4 192.168.32.1:5062 UDP target domain=unspecified mFlowKey=612 ] already in use
17:19:23.812 CallMgr::Stack::Initialize [CM101002]: Can not create UDP transport on 192.168.229.1:5062
17:19:23.812   ResipLogger:Failed to create transport: V4 UDP 5062 on 192.168.229.1
17:19:23.812   ResipLogger:[ V4 192.168.229.1:5062 UDP target domain=unspecified mFlowKey=612 ] already in use
17:19:23.812 CallMgr::Stack::Initialize [CM101002]: Can not create UDP transport on 192.168.1.223:5062
17:19:23.812   ResipLogger:Failed to create transport: V4 UDP 5062 on 192.168.1.223
17:19:23.812   ResipLogger:[ V4 192.168.1.223:5062 UDP target domain=unspecified mFlowKey=612 ] already in use
17:19:23.750 MediaServerConnected [CM112000] Media Server is connected
17:19:23.734 CallMgr::findLocalIPs [CM501006]: Default Local IP address: [192.168.1.223, 192.168.229.1, 192.168.32.1]
17:19:23.562 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
17:19:23.562 CallMgr::Initialize [CM501002]: Version: 6.0.650.0
17:19:23.562 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
17:19:23.500 LoadLicenceInfo [CM501010]: License Info: Load Failed
L'ip della macchina è 192.168.1.223 e la porta utilizzata per il protocollo sip è 5062.
L'unica cosa strana che vedo è un ip 192.168.32.1 ma non appartiene alla mia lan.
Ma quell'indirizzo fuori dalla tua lan, lo avevi usato in precedenza ? lo conosci ?
Sembra, dico sembra, che ci sia una sovrapposizione di configurazione.
Quando hai reinstallato, come hai fatto ? cancellato tutto ?
Si ho spuntato tutti e due i campi proposti (a ricordo configurazione e fax ecc.).
In tutti i casi quell'ip non è della mia lan e il ping mi da come persi
@mariog wrote:Si ho spuntato tutti e due i campi proposti (a ricordo configurazione e fax ecc.).
Io di solito dopo,per precauzione, cancello anche la directory, se rimane
Non lo puoi pingare perche' avrai la netmask a 255.255.255.0 sulla tua macchina.
Non puo' essere saltato fuori dal nulla ...
Io farei un cerca "indirizzo ip" dentro tutti i files contenuti nella cartella di 3CX.
Chissa' che non capiamo qualcosa di piu'
penso anche io che il problema dovrebbe essere questo ip
Ho di nuovo disinstallato cancellando la cartella C:Programmi3CX PhoneSystem e ho rinstallato il tutto, mi è stato richiesto di disinstallare anche il client ( ? ).
ma nel log mi continua ad apparire :
11:40:30.484 CallMgr::Stack::Initialize [CM101002]: Can not create UDP transport on 192.168.32.1:5062
11:40:30.437   ResipLogger:Failed to create transport: V4 UDP 5062 on 192.168.32.1
In lan ho controlla anche se su qualche pc fosse stata istallata qualche macchina virtuale e/o vpn, ma nulla!
Dopo questo forum, la mia unica possibilità è quella di consultare un esorcista... :lol:
Hai provato a fare come ti ho detto, cioe' cercare la stringa con quell'indirizzo ip in tutti i files della cartella di 3CX ?
prova a pulire anche il registro dopo la disistallazione
@damiano wrote:prova a pulire anche il registro dopo la disistallazione
Anzi, prima di pulirlo, fai un find nel registro di quell'indirizzo, voglio proprio vedere dove si annida.
Non se lo sara' inventato :)
Allora: gli ip che mi comparivano appartenevano alla lan che aveva creato la virtual machine di trixbox, l'ho disabilitata e da stamattina fino ad ora di pranzo tutto è andato ok, poi il pbx si è messo off line: ho riavviato il pc (non capisco perchè non si possa riavviare solo il 3cx...) ma nulla....
Vi posto il mio log:
15:33:47.687 CallCtrl::thread [CM501008]: *** Stopped Calls Controller thread ***
15:33:34.953 CServiceModule::PreMessageLoop [CM100001]: *!* Failed to initialize Call Manager *!*
15:33:34.921 CallMgr::Initialize [CM100001]: *!* Failed to initialize SIP Stack *!*
15:33:34.921 CallMgr::Stack::Initialize [CM101002]: Can not create UDP transport on 192.168.1.223:5062
15:33:34.921   ResipLogger:Failed to create transport: V4 UDP 5062 on 192.168.1.223
15:33:34.750   ResipLogger:[ V4 192.168.1.223:5062 UDP target domain=unspecified mFlowKey=652 ] already in use
15:33:34.609 CallMgr::findLocalIPs [CM501006]: Default Local IP address: [192.168.1.223]
15:33:34.531 MediaServerConnected [CM112000] Media Server is connected
15:33:33.578 CallMgr::Initialize [CM501002]: Version: 6.0.805.0
15:33:33.578 CallCtrl::thread [CM501007]: *** Started Calls Controller thread ***
15:33:33.578 CallMgr::Initialize [CM501001]: Start 3CX PhoneSystem Call Manager
15:33:33.515 LoadLicenceInfo [CM501010]: License Info: Load Failed
Suggerimeti?
certo ke puoi fermare il 3CX senza riaviare il Pc..........vai sui Servizi da Pannello di Controllo
poi prova a pulire il registro dopo aver disistallato il 3CX.......
e ricomincia da Zero
