“Il numero del destinatario non è raggiungibile, non è registrato o non vi sono route disponibili”
il registro invece è il seguente:
10/02/2022 13:34:11 - Leg L:312.1[Extn:441] is terminated: Cause: BYE from local
10/02/2022 13:34:11 - [CM503008]: Call(C:312): Call is terminated
10/02/2022 13:34:11 - Leg L:312.2[EndCall:EndCall] is terminated: Cause: BYE from 127.0.0.1:5483
10/02/2022 13:34:04 - [CM503007]: Call(C:312): Extn:441 has joined, contact <sip:
[email protected]:5060/UDP>
10/02/2022 13:34:04 - [CM503007]: Call(C:312): EndCall:EndCall has joined, contact <sip:
[email protected]:5483/UDP>
10/02/2022 13:34:04 - L:312.2[EndCall:EndCall] has joined to L:312.1[Extn:441]
10/02/2022 13:34:04 - [CM503002]: Call(C:312): Alerting EndCall:EndCall by contact <sip:
10/02/2022 13:34:04 - [CM503025]: Call(C:312): Calling T:EndCall:EndCall@[Dev:sip:
[email protected]:5483;rinstance=c88538dda831c18e] for L:312.1[Extn:441]
10/02/2022 13:34:04 - L:312.1[Extn:441] failed to reach Out#:>>Rule{solo 441}>>0982?????, reason Temporarily Unavailable
10/02/2022 13:34:04 - [CM503026]: Call(C:312): Route 1 to UnknownTrunk:15 is not active (Busy/Not registered)
10/02/2022 13:34:04 - : Failed to create outbound lines to call 0982?????
10/02/2022 13:34:04 - Call(C:312): Call from Extn:441 to 0982????? matches outbound rule 'solo 441'
10/02/2022 13:34:04 - [Flow] Call(C:312): has built target endpoint: Out#:>>Rule{solo 441}>>0982????? for call from L:312.1[Extn:441]
10/02/2022 13:34:04 - [Flow] Target endpoint for 0982????? is Out#:>>Rule{solo 441}>>0982?????
10/02/2022 13:34:04 - [CM503010]: Call(C:312): Making route(s) from Extn:441 to <sip:0982?????@????????.my3cx.it:0/UDP>
10/02/2022 13:34:04 - [CM505001]: Endpoint Extn:441: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iOS 18.0.2.186] PBX contact: [sip:
[email protected]:5060]
10/02/2022 13:34:04 - [CM500002]: Call(C:312): Info on incoming INVITE from Extn:441:
Invite-IN Recv Req INVITE from 127.0.0.1:5080 tid=PjO2wOsbGvYnsHJKGuj2NjfkLbX3ARqO5x Call-ID=2I0rUGGAgsf2BYYPFu5yg8p6gqxK-ioq:
INVITE sip:
[email protected]:5060;transport=UDP;tag3cx=covriva7 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5080;branch=z9hG4bK-524287-2---PjO2wOsbGvYnsHJKGuj2NjfkLbX3ARqO5x;rport=5080
Via: SIP/2.0/UDP [::ffff:5.91.104.142]:45370;branch=z9hG4bK-524287-1---tunneltid;rport;tnlid=clnt.0-4xnerpo-fz8yv7onxb11lxa.anpzgjbk_212990
Via: SIP/2.0/TCP 127.0.0.1:50195;rport;branch=z9hG4bKPjO2wOsbGvYnsHJKGuj2NjfkLbX3ARqO5x;alias
Max-Forwards: 69
Record-Route: <sip:
[email protected]:5080;user=proxy;uri=clnt.0-4xnerpo-fz8yv7onxb11lxa.anpzgjbk_212990>
Contact: "Mauro" <sip:
[email protected]:5060;rinstance=0-4xnerpo-fz8yv7onxb11lxa.anpzgjbk>
To: <sip:0982?????@????????.my3cx.it;tag3cx=covriva7>
From: "Mauro"<sip:441@????????.my3cx.it>;tag=qb-4VHFM7HEAV--1q-ipA0uMIcTDCG-N
Call-ID: 2I0rUGGAgsf2BYYPFu5yg8p6gqxK-ioq
CSeq: 166 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Type: application/sdp
Proxy-Authorization: Digest username="hM8c71fjVC",realm="3CXPhoneSystem",nonce="414d53596205063c61:ad9167a8a203065405f4791ad8dce0ca",uri="sip:0982?????@????????.my3cx.it;tag3cx=covriva7",response="0be38710d81b0dbe40f9cb4a629ccae4",algorithm=MD5
Supported: replaces, 100rel, timer, norefersub
User-Agent: 3CXPhone for iOS 18.0.2.186
Content-Length: 441
v=0
o=- 3853485244 3853485244 IN IP4 100.64.95.70
s=pjmedia
b=AS:117
t=0 0
a=X-nat:0
m=audio 10000 RTP/AVP 18 8 0 9 125 101
c=IN IP4 100.64.95.70
b=TIAS:96000
b=AS:117
a=rtcp:10001
a=sendrecv
a=rtpmap:18 G729/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:9 G722/8000
a=rtpmap:125 opus/48000/2
a=fmtp:125 useinbandfec=1
a=fmtp:101 0-15
m=video 0 RTP/AVP 31
c=IN IP4 127.0.0.1
10/02/2022 13:34:04 - [CM503001]: Call(C:312): Incoming call from Extn:441 to <sip:0982??????@?????????.my3cx.it:0>
10/02/2022 13:33:56 - Timezone offset: 60 min.
