SSL Certificate renewal has been failed
VRTech
23 Giugno 2021
Buongiorno, non riusciamo a capire il motivo dell'errore in questione.
Licenza PRO 16C Versione 20.0 Update 3 (Build 806 Release)
Livello
Errore
ID evento
50011
Data e ora
13/10/2024 04:45
Dettagli
SSL Certificate renewal has been failed. Error: IpUpdater.FqdnGenerationException: Can not create FQDN in 600 seconds at PostInstall.CertificateGenerator.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, PhoneSystem ps, Int32 regenerateCertificateExiredInDays, UInt16 sipPort, UInt16 tunnelPort, Nullable`1 httpPort, Nullable`1 httpsPort, Boolean isPassiveFailoverMode, Boolean enableDnsHelper) at PostInstall.CertificateGenerator.RenewCertificates(String appBin, String appData) A communication error occurred between the DNS Servers and LetsEncrypt. This rarely happens and is usually resolved on the second attempt. 3CX will try again.
OK
Errore5001113/10/2024 04:45System ManagerSSL Certificate renewal has been failed. Error: IpUpdater.FqdnGenerationException: Can not create FQDN in 600 seconds at PostInstall.CertificateGenerator.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, PhoneSystem ps, Int32 regenerateCertificateExiredInDays, UInt16 sipPort, UInt16 tunnelPort, Nullable`1 httpPort, Nullable`1 httpsPort, Boolean isPassiveFailoverMode, Boolean enableDnsHelper) at PostInstall.CertificateGenerator.RenewCertificates(String appBin, String appData) A communication error occurred between the DNS Servers and LetsEncrypt. This rarely happens and is usually resolved on the second attempt. 3CX will try again.
Info1002713/10/2024 02:00System ManagerDatabase maintenance task has been finished.
Info1002912/10/2024 15:13Web ManagerCENTRALINOProvisioning file for MAC 0C383E5BEF5F of user 201 requested by 31.27.55.90 was successfully generated
Info1003312/10/2024 14:36Web ManagerYour license has been successfully activated.
Info1002912/10/2024 14:08Web ManagerCENTRALINOProvisioning file for MAC 0C383E5BEF2D of user 202 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 13:05Web ManagerMEDICIProvisioning file for MAC 0C383E59521E of user 107 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 12:46Web ManagerMEDICIProvisioning file for MAC 0C383E59523D of user 104 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 12:39Web ManagerMEDICIProvisioning file for MAC 0C383E59523A of user 102 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 12:07Web ManagerMEDICIProvisioning file for MAC 0C383E595245 of user 103 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 11:59Web ManagerMEDICIProvisioning file for MAC 0C383E59523C of user 106 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 10:07Web ManagerMEDICIProvisioning file for MAC 0C383E59523B of user 101 requested by 31.27.55.90 was successfully generated
Info1002912/10/2024 09:45Web ManagerDEFAULTProvisioning file for MAC 0C383E59523E of user 105 requested by 31.27.55.90 was successfully generated
Info410012/10/2024 04:34SIP ServerTrunk L:10005(TRUNK MED 5) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10007(TRUNK MED 7) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10000(TRUNK MED 1) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10003(TRUNK MED 4) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10004(TRUNK MED 3) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10002(TRUNK MED 2) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10006(TRUNK MED 6) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:10001(TRUNK CENTR ESTE) has changed status to registered.
Info410012/10/2024 04:34SIP ServerTrunk L:90000(WebMeeting bridge) has changed status to registered.
Info409712/10/2024 04:34SIP ServerService started
Info1000912/10/2024 04:31Web Manager3CX was successfully updated.
Risolto in autonomia
